ActiveX 开发指南
相关分类
半径属性 (ActiveX)
2023-1-3 07:40| 发布者: admin| 查看: 1843| 评论: 0|来自: AutoCAD
摘要: 指定圆弧、圆或位置标记的半径。
指定圆弧、圆或位置标记的半径。
支持的平台:仅窗口
工 务 局:
object.Radius
类型:圆弧,圆形,地理位置标记
此属性适用的对象。
只读:不
类型:双
圆弧、圆或位置标记的半径。
圆的半径
工 务 局:
Sub Example_Radius()
    ' This example creates an arc in model space.
    ' It then returns the radius of the arc.
    Dim arcObj As AcadArc
    Dim radius As Double
    Dim startAngleInDegree As Double
    Dim endAngleInDegree As Double
    ' Define the circle
    centerPoint(0) = 0#: centerPoint(1) = 0#: centerPoint(2) = 0#
    radius = 5#
    startAngleInDegree = 10#
    endAngleInDegree = 230#
    ' Convert the angles in degrees to angles in radians
    Dim startAngleInRadian As Double
    Dim endAngleInRadian As Double
    startAngleInRadian = startAngleInDegree * 3.141592 / 180#
    endAngleInRadian = endAngleInDegree * 3.141592 / 180#
    ' Create the arc object in model space
    Set arcObj = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngleInRadian, endAngleInRadian)
    ZoomAll
    ' Find the radius of the arc
    radius = arcObj.radius
    MsgBox "The radius of the arc is " & arcObj.radius, , "Radius Example"
Visual LISP:
(defun c:Example_Radius()
    ;; This example creates an arc in model space.
    ;; It then returns the radius of the arc.
    ;; Define the circle
    (setq centerPoint (vlax-3d-point 0 0 0)
          radius 5
          startAngleInDegree 10
          endAngleInDegree 230)
    ;; Convert the angles in degrees to angles in radians
    (setq startAngleInRadian (/ (* startAngleInDegree 3.141592) 180))
    (setq endAngleInRadian (/ (* endAngleInDegree 3.141592) 180))
    ;; Create the arc object in model space
    (setq arcObj (vla-AddArc modelSpace centerPoint radius startAngleInRadian endAngleInRadian))
    (vla-ZoomAll acadObj)
    ;; Find the radius of the arc
    (alert (strcat "The radius of the arc is " (rtos (vla-get-Radius arcObj))))
GMT+8, 2026-10-27 15:06
