指定属性的提示字符串。 支持的平台:仅窗口 属性值只读:不 类型:字符串 属性的提示字符串。 言论插入包含此属性的块时,将显示此字符串。此字符串的默认值为属性。输入属性将禁用提示。TagStringacAttributeModeConstantMode 例子工 务 局: Sub Example_PromptString()
' This example creates an attribute definition in a block.
' It then inserts the block. Then it changes the prompt string
' of the attribute definition, and inserts the block again.
' Create the block
Dim blockObj As AcadBlock
Dim insertionPnt(0 To 2) As Double
insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "TEST")
' Add a circle to block
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 0: center(1) = 0: center(2) = 0
radius = 1
Set circleObj = blockObj.AddCircle(center, radius)
' Define the attribute definition
Dim attributeObj As AcadAttribute
Dim height As Double
Dim mode As Integer
Dim prompt As String
Dim tag As String
Dim value As String
height = 1#
mode = acAttributeModeVerify
prompt = "Enter value:"
tag = "Tag1"
value = "Circle1"
' Create the attribute definition on the block
Set attributeObj = blockObj.AddAttribute(height, mode, prompt, insertionPnt, tag, value)
' Insert the block
Dim blockRefObj1 As AcadBlockReference
insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
Set blockRefObj1 = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "TEST", 1#, 1#, 1#, 0)
' Change the prompt string and tag of the attribute definition
attributeObj.PromptString = "Verify value:"
' Insert the block again
Dim blockRefObj2 As AcadBlockReference
insertionPnt(0) = 4#: insertionPnt(1) = 4#: insertionPnt(2) = 0
Set blockRefObj2 = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "TEST", 1#, 1#, 1#, 0)
ZoomAll
Visual LISP: (vl-load-com)
(defun c:Example_PromptString()
;; This example creates an attribute definition in a block.
;; It then inserts the block. Then it changes the prompt string
;; of the attribute definition, and inserts the block again.
;; Create the block
(setq insertionPnt (vlax-3d-point 0 0 0))
(setq blockObj (vla-Add (vla-get-Blocks doc) insertionPnt "TEST"))
;; Add a circle to block
(setq center (vlax-3d-point 0 0 0)
radius 1)
(setq circleObj (vla-AddCircle blockObj center radius))
;; Define the attribute definition
(setq insertionPoint (vlax-3d-point 0 0 0)
attHeight 1
attMode acAttributeModeVerify
attPrompt "Enter value:"
attTag "Tag1"
attValue "Circle1")
;; Create the attribute definition on the block
(setq attributeObj (vla-AddAttribute blockObj attHeight attMode attPrompt insertionPoint attTag attValue))
;; Insert the block
(setq insertionPnt (vlax-3d-point 2 2 0))
(setq blockRefObj1 (vla-InsertBlock modelSpace insertionPnt "TEST" 1 1 1 0))
;; Change the prompt string and tag of the attribute definition
(vla-put-PromptString attributeObj "Verify value:")
;; Insert the block again
(setq insertionPnt (vlax-3d-point 4 4 0))
(setq blockRefObj2 (vla-InsertBlock modelSpace insertionPnt "TEST" 1 1 1 0))
(vla-ZoomAll acadObj)
GMT+8, 2026-10-25 19:55
