指定用于后台打印的应用程序。 支持的平台:仅窗口 属性值只读:不 类型:字符串 后台打印应用程序。 言论此属性包含要与自动后台打印一起使用的打印后台打印可执行文件的驱动器、路径和应用程序名称。 例子工 务 局: Sub Example_PrintSpoolExecutable()
' PrintSpoolExecutable. It then changes the value, and finally
Dim currPrintSpoolExecutable As String
Dim newPrintSpoolExecutable As String
Set preferences = ThisDrawing.Application.Preferences
' Retrieve the current PrintSpoolExecutable value
currPrintSpoolExecutable = preferences.Files.PrintSpoolExecutable
MsgBox "The current value for PrintSpoolExecutable is " & currPrintSpoolExecutable, vbInformation, "PrintSpoolExecutable Example"
' Change the value for PrintSpoolExecutable
newPrintSpoolExecutable = "TestPrintSpoolExecutable"
preferences.Files.PrintSpoolExecutable = newPrintSpoolExecutable
MsgBox "The new value for PrintSpoolExecutable is " & newPrintSpoolExecutable, vbInformation, "PrintSpoolExecutable Example"
' Reset PrintSpoolExecutable to its original value
preferences.Files.PrintSpoolExecutable = currPrintSpoolExecutable
MsgBox "The PrintSpoolExecutable value is reset to " & currPrintSpoolExecutable, vbInformation, "PrintSpoolExecutable Example"
Visual LISP: (vl-load-com)
(defun c:Example_PrintSpoolExecutable()
;; PrintSpoolExecutable. It then changes the value, and finally
;; Retrieve the current PrintSpoolExecutable value
(setq currPrintSpoolExecutable (vla-get-PrintSpoolExecutable (vla-get-Files preferences)))
(alert (strcat "The current value for PrintSpoolExecutable is " currPrintSpoolExecutable))
;; Change the value for PrintSpoolExecutable
(setq newPrintSpoolExecutable "TestPrintSpoolExecutable")
(vla-put-PrintSpoolExecutable (vla-get-Files preferences) newPrintSpoolExecutable)
(alert (strcat "The new value for PrintSpoolExecutable is " newPrintSpoolExecutable))
;; Reset PrintSpoolExecutable to its original value
(vla-put-PrintSpoolExecutable (vla-get-Files preferences) currPrintSpoolExecutable)
(alert (strcat "The PrintSpoolExecutable value is reset to " currPrintSpoolExecutable))
GMT+8, 2026-11-2 03:36
