ActiveX 开发指南
相关分类
打印后台处理程序路径属性 (ActiveX)
2023-1-3 07:58| 发布者: admin| 查看: 1775| 评论: 0|来自: AutoCAD
摘要: 指定打印后台打印文件的目录。AutoCAD 将打印写入此位置。
支持的平台:仅窗口
工 务 局:
object.PrintSpoolerPath
类型:首选项文件
此属性适用的对象。
只读:不
类型:字符串
打印后台打印文件的目录。
没有额外的评论。
工 务 局:
Sub Example_PrintSpoolerPath()
    ' PrintSpoolerPath. It then changes the value, and finally
    Dim currPrintSpoolerPath As String
    Dim newPrintSpoolerPath As String
    Set preferences = ThisDrawing.Application.Preferences
    ' Retrieve the current PrintSpoolerPath value
    currPrintSpoolerPath = preferences.Files.PrintSpoolerPath
    MsgBox "The current value for PrintSpoolerPath is " & currPrintSpoolerPath, vbInformation, "PrintSpoolerPath Example"
    ' Change the value for PrintSpoolerPath
    newPrintSpoolerPath = "TestPrintSpoolerPath"
    preferences.Files.PrintSpoolerPath = newPrintSpoolerPath
    MsgBox "The new value for PrintSpoolerPath is " & newPrintSpoolerPath, vbInformation, "PrintSpoolerPath Example"
    ' Reset PrintSpoolerPath to its original value
    preferences.Files.PrintSpoolerPath = currPrintSpoolerPath
    MsgBox "The PrintSpoolerPath value is reset to " & currPrintSpoolerPath, vbInformation, "PrintSpoolerPath Example"
Visual LISP:
(defun c:Example_PrintSpoolerPath()
    ;; PrintSpoolerPath. It then changes the value, and finally
    ;; Retrieve the current PrintSpoolerPath value
    (setq currPrintSpoolerPath (vla-get-PrintSpoolerPath (vla-get-Files preferences)))
    (alert (strcat "The current value for PrintSpoolerPath is " currPrintSpoolerPath))
    ;; Change the value for PrintSpoolerPath
    (setq newPrintSpoolerPath "TestPrintSpoolerPath")
    (vla-put-PrintSpoolerPath (vla-get-Files preferences) newPrintSpoolerPath)
    (alert (strcat "The new value for PrintSpoolerPath is " newPrintSpoolerPath))
    ;; Reset PrintSpoolerPath to its original value
    (vla-put-PrintSpoolerPath (vla-get-Files preferences) currPrintSpoolerPath)
    (alert (strcat "The PrintSpoolerPath value is reset to " currPrintSpoolerPath))
GMT+8, 2026-11-2 19:06
