指定用于临时打印文件名的备用名称。 支持的平台:仅窗口 属性值只读:不 类型:字符串 打印文件的备用名称。输入“.”以使用默认值(当前图形名称)。输入备用打印文件的驱动器、路径和文件名。 言论默认名称是图形的名称加上文件扩展名 .plt。 例子工 务 局: Sub Example_PrintFile()
' PrintFile. It then changes the value, and finally
Dim currPrintFile As String
Dim newPrintFile As String
Set preferences = ThisDrawing.Application.Preferences
' Retrieve the current PrintFile value
currPrintFile = preferences.Files.PrintFile
MsgBox "The current value for PrintFile is " & currPrintFile, vbInformation, "PrintFile Example"
' Change the value for PrintFile
newPrintFile = "TestPrintFile.plt"
preferences.Files.PrintFile = newPrintFile
MsgBox "The new value for PrintFile is " & newPrintFile, vbInformation, "PrintFile Example"
' Reset PrintFile to its original value
preferences.Files.PrintFile = currPrintFile
MsgBox "The PrintFile value is reset to " & currPrintFile, vbInformation, "PrintFile Example"
Visual LISP: (vl-load-com)
(defun c:Example_PrintFile()
;; PrintFile. It then changes the value, and finally
;; Retrieve the current PrintFile value
(setq currPrintFile (vla-get-PrintFile (vla-get-Files preferences)))
(alert (strcat "The current value for PrintFile is " currPrintFile))
;; Change the value for PrintFile
(setq newValue "TestPrintFile.plt")
(vla-put-PrintFile (vla-get-Files preferences) newValue)
(alert (strcat "The new value for PrintFile is " newValue))
;; Reset PrintFile to its original value
(vla-put-PrintFile (vla-get-Files preferences) currPrintFile)
(alert (strcat "The PrintFile value is reset to " currPrintFile))
GMT+8, 2026-11-3 11:23
