指定当版面配置的纸张大小与 PC3 文件的默认设置不同时,是否向用户发出警报。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。True 例子工 务 局: Sub Example_PrinterPaperSizeAlert()
' This example reads and modifies the PrinterPaperSizeAlert
' preference value.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesOutput
Dim originalValue As Boolean
' Get the user preferences object
Set ACADPref = ThisDrawing.Application.Preferences.Output
originalValue = ACADPref.PrinterPaperSizeAlert
MsgBox "The PrinterPaperSizeAlert preference is set to: " & originalValue
' Modify the PrinterPaperSizeAlert preference by toggling the value
ACADPref.PrinterPaperSizeAlert = Not ACADPref.PrinterPaperSizeAlert
MsgBox "The PrinterPaperSizeAlert preference has been set to: " & ACADPref.PrinterPaperSizeAlert
ACADPref.PrinterPaperSizeAlert = originalValue
MsgBox "The PrinterPaperSizeAlert preference was reset back to: " & originalValue
Visual LISP: (vl-load-com)
(defun c:Example_PrinterPaperSizeAlert()
;; This example reads and modifies the PrinterPaperSizeAlert
;; preference value.
;; When finished, this example resets the preference value back to
;; its original value.
(setq originalValue (vla-get-PrinterPaperSizeAlert (vla-get-Output preferences)))
(alert (strcat "The PrinterPaperSizeAlert preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the PrinterPaperSizeAlert preference by toggling the value
(vla-put-PrinterPaperSizeAlert (vla-get-Output preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(alert (strcat "The PrinterPaperSizeAlert preference has been set to: " (if (= (vla-get-PrinterPaperSizeAlert (vla-get-Output preferences)) :vlax-true) "True" "False")))
(vla-put-PrinterPaperSizeAlert (vla-get-Output preferences) originalValue)
(alert (strcat "The PrinterPaperSizeAlert preference was reset back to: " (if (= (vla-get-PrinterPaperSizeAlert (vla-get-Output preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-10-26 02:53
