指定打印机说明文件的位置。 支持的平台:仅窗口 属性值只读:不 类型:字符串 打印机描述文件的驱动器和路径。 言论没有额外的评论。 例子工 务 局: Sub Example_PrinterDescPath()
' This example reads and modifies the preference value that controls
' the location for printer description files.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesFiles
' Get the files preferences object
Set ACADPref = ThisDrawing.Application.Preferences.Files
originalValue = ACADPref.PrinterDescPath
MsgBox "The PrinterDescPath preference is set to: " & originalValue
' Modify the PrinterDescPath preference by changing the path to "C:\"
ACADPref.PrinterDescPath = "C:\"
newValue = ACADPref.PrinterDescPath
MsgBox "The PrinterDescPath preference has been set to: " & newValue
' this preference in effect
ACADPref.PrinterDescPath = originalValue
MsgBox "The PrinterDescPath preference was reset back to: " & originalValue
Visual LISP: (vl-load-com)
(defun c:Example_PrinterDescPath()
;; This example reads and modifies the preference value that controls
;; the location for printer description files.
;; When finished, this example resets the preference value back to
;; its original value.
(setq originalValue (vla-get-PrinterDescPath (vla-get-Files preferences)))
(alert (strcat "The PrinterDescPath preference is set to: " originalValue))
;; Modify the PrinterDescPath preference by changing the path to "C:\\"
(vla-put-PrinterDescPath (vla-get-Files preferences) "C:\\")
(setq newValue (vla-get-PrinterDescPath (vla-get-Files preferences)))
(alert (strcat "The PrinterDescPath preference has been set to: " newValue))
;; this preference in effect
(vla-put-PrinterDescPath (vla-get-Files preferences) originalValue)
(alert (strcat "The PrinterDescPath preference was reset back to: " originalValue))
GMT+8, 2026-10-24 10:08
