ActiveX 开发指南
相关分类
PlotWithPlotStyles Property (ActiveX)
2023-1-3 08:23| 发布者: admin| 查看: 2091| 评论: 0|来自: AutoCAD
摘要: 指定是否使用应用于对象并在打印样式表中定义的打印样式进行打印。
支持的平台:仅窗口
工 务 局:
object.PlotWithPlotStyles
类型:布局,绘图配置
此属性适用的对象。
只读:不
类型:布尔
  • True:打印时使用应用于对象的打印样式。
  • False:打印时不要使用应用于对象的打印样式。
该属性等效于 AutoCAD 中的“使用打印样式打印”选项。PlotWithPlotStyles
工 务 局:
Sub Example_PlotWithPlotStyles()
    ' This example reads and changes the PlotWithPlotStyles
    ' value, and shows a plot preview so the user can see the change.
    Dim ACADLayout As ACADLayout
    Dim originalValue As Boolean
    ' Get the layout object
    Set ACADLayout = ThisDrawing.ActiveLayout
    originalValue = ACADLayout.PlotWithPlotStyles
    MsgBox "The PlotWithPlotStyles value is set to: " & originalValue
    ' Modify the PlotWithPlotStyles preference by changing the value
    ACADLayout.PlotWithPlotStyles = Not ACADLayout.PlotWithPlotStyles
    MsgBox "The PlotWithPlotStyles preference has been set to: " & ACADLayout.PlotWithPlotStyles
    ThisDrawing.ActiveLayout.ConfigName = "DWF6 ePlot.pc3"
    'Show plot preview
    ThisDrawing.Plot.DisplayPlotPreview acFullPreview
Visual LISP:
(defun c:Example_PlotWithPlotStyles()
    ;; This example reads and changes the PlotWithPlotStyles
    ;; value, and shows a plot preview so the user can see the change.
    ;; Get the layout object
    (setq ACADLayout (vla-get-ActiveLayout doc))
    (setq originalValue (vla-get-PlotWithPlotStyles ACADLayout))
    (alert (strcat "The PlotWithPlotStyles value is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the PlotWithPlotStyles preference by changing the value
    (vla-put-PlotWithPlotStyles ACADLayout (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-PlotWithPlotStyles ACADLayout))
    (alert (strcat "The PlotWithPlotStyles preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    ;; Set an output device current
    (if (= (strcase (vla-get-ConfigName (vla-get-ActiveLayout doc))) "NONE")
        (vla-put-ConfigName (vla-get-ActiveLayout doc) "DWF6 ePlot.pc3")
    ;; Show plot preview
    (vla-DisplayPlotPreview (vla-get-Plot doc) acFullPreview)
GMT+8, 2026-10-27 21:12
