指定对象、对象组或图层的打印样式名称。 支持的平台:仅窗口 签名工 务 局: object.PlotStyleName
属性值只读:不;除了只写的对象Group 类型:字符串 对象的打印样式名称。 言论没有额外的评论。 例子工 务 局: Sub Example_PlotStyleName()
' This example creates a circle in model space and then
' finds the current PlotStyleName for the circle.
Dim circleObj As AcadCircle
Dim radius As Double
' Define the circle
centerPoint(0) = 0#: centerPoint(1) = 0#: centerPoint(2) = 0#
radius = 5#
' Create the Circle object in model space
Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
ZoomAll
' Find the PlotStyleName for the circle
MsgBox "The current PlotStyleName for the circle is " & circleObj.PlotStyleName
Visual LISP: (vl-load-com)
(defun c:Example_PlotStyleName()
;; This example creates a circle in model space and then
;; finds the current PlotStyleName for the circle.
;; Define the circle
(setq centerPoint (vlax-3d-point 0 0 0)
radius 5)
;; Create the Circle object in model space
(setq circleObj (vla-AddCircle modelSpace centerPoint radius))
(vla-ZoomAll acadObj)
;; Find the PlotStyleName for the circle
(alert (strcat "The current PlotStyleName for the circle is " (vla-get-PlotStyleName circleObj)))
GMT+8, 2026-11-16 20:02
