获取文档的 Plot 对象。 支持的平台:仅窗口 言论没有额外的评论。 例子工 务 局: Sub Example_Plot()
' This example sends a plot of the current drawing
' to a file.
ThisDrawing.ActiveLayout.ConfigName = "DWF6 ePlot.pc3"
' Define the plot variable
Dim currentPlot As AcadPlot
Set currentPlot = ThisDrawing.Plot
' Define the output file name.
' Use "" to use the drawing name as the file name.
' Note: if the file name exists an error will be generated.
Dim plotFileName As String
plotFileName = "MyPlot"
currentPlot.PlotToFile plotFileName
Visual LISP: (vl-load-com)
(defun c:Example_Plot()
;; This example sends a plot of the current drawing
;; to a file.
;; Set a device current that outputs to a file
(vla-put-ConfigName (vla-get-ActiveLayout doc) "DWF6 ePlot.pc3")
;; Define the plot variable
(setq currentPlot (vla-get-Plot doc))
;; Define the output file name.
;; Use "" to use the drawing name as the file name.
;; Note: if the file name exists an error will be generated.
(setq plotFileName "MyPlot")
(vla-PlotToFile currentPlot plotFileName)
GMT+8, 2026-10-30 18:31
