确定是在发出命令之前(名词谓词选择)还是之后选择对象。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。True 注意:此属性的值存储在 PICKFIRST 系统变量中。
例子工 务 局: Sub Example_PickFirst()
' This example reads and modifies the preference value that controls
' whether you select objects before (noun-verb selection) or after
' you issue a command.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesSelection
' Get the selection preferences object
Set ACADPref = ThisDrawing.Application.Preferences.Selection
originalValue = ACADPref.PickFirst
MsgBox "The PickFirst preference is set to: " & originalValue
' Modify the PickFirst preference by toggling the value
ACADPref.PickFirst = Not (ACADPref.PickFirst)
newValue = ACADPref.PickFirst
MsgBox "The PickFirst preference has been set to: " & newValue
' this preference in effect
ACADPref.PickFirst = originalValue
MsgBox "The PickFirst preference was reset back to: " & originalValue
Visual LISP: (vl-load-com)
(defun c:Example_PickFirst()
;; This example reads and modifies the preference value that controls
;; whether you select objects before (noun-verb selection) or after
;; you issue a command.
;; When finished, this example resets the preference value back to
;; its original value.
(setq originalValue (vla-get-PickFirst (vla-get-Selection preferences)))
(alert (strcat "The PickFirst preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the PickFirst preference by toggling the value
(vla-put-PickFirst (vla-get-Selection preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-PickFirst (vla-get-Selection preferences)))
(alert (strcat "The PickFirst preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-PickFirst (vla-get-Selection preferences) originalValue)
(alert (strcat "The PickFirst preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-26 21:47
