指定视区的等轴测捕捉模式的状态。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论没有额外的评论。 例子工 务 局: Sub Example_OrthoOn()
' This example toggles the setting of OrthoOn.
Dim viewportObj As AcadViewport
' Set the viewportObj variable to the activeviewport
Set viewportObj = ThisDrawing.ActiveViewport
' Display the current setting of OrthoOn
MsgBox "Isometric snap mode is: " & IIf(viewportObj.OrthoOn, "On", "Off"), , "OrthoOn Example"
' Toggle the setting of OrthoOn
viewportObj.OrthoOn = Not (viewportObj.OrthoOn)
' Reset the active viewport to see the change on the AutoCAD status bar
ThisDrawing.ActiveViewport = viewportObj
MsgBox "Isometric snap mode is now: " & IIf(viewportObj.OrthoOn, "On", "Off"), , "OrthoOn Example"
Visual LISP: (vl-load-com)
(defun c:Example_OrthoOn()
;; This example toggles the setting of OrthoOn.
;; Set the viewportObj variable to the activeviewport
(setq viewportObj (vla-get-ActiveViewport doc))
;; Display the current setting of OrthoOn
(alert (strcat "Isometric snap mode is: " (if (= (vla-get-OrthoOn viewportObj) :vlax-true) "On" "Off")))
;; Toggle the setting of OrthoOn
(vla-put-OrthoOn viewportObj (if (= (vla-get-OrthoOn viewportObj) :vlax-true) :vlax-false :vlax-true))
;; Reset the active viewport to see the change on the AutoCAD status bar
(vla-put-ActiveViewport doc viewportObj)
(alert (strcat "Isometric snap mode is now: " (if (= (vla-get-OrthoOn viewportObj) :vlax-true) "On" "Off")))
GMT+8, 2026-11-13 02:11
