确定在打印 OLE 对象时是否启动父应用程序。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。False 从父应用程序进行绘图可实现更高质量的绘图;但是,情节的速度降低了。 注意:此属性的值存储在 OLESTARTUP 系统变量中。
例子工 务 局: Sub Example_OLELaunch()
' This example reads and modifies the preference value that controls
' whether to launch the parent application when plotting OLE objects.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadDatabasePreferences
' Get the user preferences object
Set ACADPref = ThisDrawing.preferences
originalValue = ACADPref.OLELaunch
MsgBox "The OLELaunch preference is set to: " & originalValue
' Modify the OLELaunch preference by toggling the value
ACADPref.OLELaunch = Not (ACADPref.OLELaunch)
newValue = ACADPref.OLELaunch
MsgBox "The OLELaunch preference has been set to: " & newValue
' this preference in effect
ACADPref.OLELaunch = originalValue
MsgBox "The OLELaunch preference was reset back to: " & originalValue
Visual LISP: (vl-load-com)
(defun c:Example_OLELaunch()
;; This example reads and modifies the preference value that controls
;; whether to launch the parent application when plotting OLE objects.
;; When finished, this example resets the preference value back to
;; its original value.
(setq preferences (vla-get-Preferences doc))
(setq originalValue (vla-get-OLELaunch preferences))
(alert (strcat "The OLELaunch preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the OLELaunch preference by toggling the value
(vla-put-OLELaunch preferences (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-OLELaunch preferences))
(alert (strcat "The OLELaunch preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-OLELaunch preferences originalValue)
(alert (strcat "The OLELaunch preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-26 02:53
