按 PostScript 输出顺序切换图形对象的排序。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。True AutoCAD 最初仅允许对打印和 PostScript 输出进行排序。设置其他排序选项可能会导致再生和重绘时间变慢。 注意:此属性的值存储在 SORTENTS 系统变量中。
例子工 务 局: Sub Example_ObjectSortByPSOutput()
' This example reads and modifies the preference value which controls
' the sorting of drawing objects by PostScript output order.
' When finished, this example resets the preference value back to
' it's original value.
Dim ACADPref As AcadDatabasePreferences
' Get the user preferences object
Set ACADPref = ThisDrawing.preferences
originalValue = ACADPref.ObjectSortByPSOutput
MsgBox "The ObjectSortByPSOutput preference is set to: " & originalValue
' Modify the ObjectSortByPSOutput preference by toggling the value
ACADPref.ObjectSortByPSOutput = Not (ACADPref.ObjectSortByPSOutput)
newValue = ACADPref.ObjectSortByPSOutput
MsgBox "The ObjectSortByPSOutput preference has been set to: " & newValue
' Reset the preference back to it's original value
' this preference in effect
ACADPref.ObjectSortByPSOutput = originalValue
MsgBox "The ObjectSortByPSOutput preference was reset back to: " & originalValue
Visual LISP: (vl-load-com)
(defun c:Example_ObjectSortByPSOutput()
;; This example reads and modifies the preference value which controls
;; the sorting of drawing objects by PostScript output order.
;; When finished, this example resets the preference value back to
;; it's original value.
(setq preferences (vla-get-Preferences doc))
(setq originalValue (vla-get-ObjectSortByPSOutput preferences))
(alert (strcat "The ObjectSortByPSOutput preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the ObjectSortByPSOutput preference by toggling the value
(vla-put-ObjectSortByPSOutput preferences (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-ObjectSortByPSOutput preferences))
(alert (strcat "The ObjectSortByPSOutput preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
;; Reset the preference back to it's original value
;; this preference in effect
(vla-put-ObjectSortByPSOutput preferences originalValue)
(alert (strcat "The ObjectSortByPSOutput preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-11-1 10:59
