ActiveX 开发指南
相关分类
NumberOfFaces Property (ActiveX)
2023-1-3 10:13| 发布者: admin| 查看: 1676| 评论: 0|来自: AutoCAD
摘要: 获取多边形网格的面数。
获取多边形网格的面数。
支持的平台:仅窗口
工 务 局:
object.NumberOfFaces
类型:多边形网格
此属性适用的对象。
只读:是的
类型:长
面数为。PolyfaceMesh
没有额外的评论。
工 务 局:
Sub Example_NumberOfFaces()
    ' This example creates a PolyFaceMesh and displays the number of faces it contains
    Dim vertexList(0 To 17) As Double
    Dim FaceList(0 To 7) As Integer
    Dim NewPolyFaceMeshObj As AcadPolyfaceMesh
    Dim direction(0 To 2) As Double
    'Data for new PolyFaceMesh object
    vertexList(0) = 4: vertexList(1) = 7: vertexList(2) = 0
    vertexList(3) = 5: vertexList(4) = 7: vertexList(5) = 0
    vertexList(6) = 6: vertexList(7) = 7: vertexList(8) = 0
    vertexList(9) = 4: vertexList(10) = 6: vertexList(11) = 0
    vertexList(12) = 5: vertexList(13) = 6: vertexList(14) = 0
    vertexList(15) = 6: vertexList(16) = 6: vertexList(17) = 6
    FaceList(0) = 1:    FaceList(1) = 2:    FaceList(2) = 5
    FaceList(3) = 4:    FaceList(4) = 2:    FaceList(5) = 3
    FaceList(6) = 6:    FaceList(7) = 5
    ' Create new PolyFaceMesh object
    Set NewPolyFaceMeshObj = ModelSpace.AddPolyfaceMesh(vertexList, FaceList)
    NewPolyFaceMeshObj.Update
    ' Change the viewing direction of the viewport to
    ' better see the polyface mesh
    direction(0) = -1: direction(1) = -1: direction(2) = 1
    ThisDrawing.ActiveViewport.direction = direction
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ' Display number of faces in this PolyFaceMesh
    MsgBox "The new PolyFaceMesh contains " & NewPolyFaceMeshObj.NumberOfFaces & " faces."
Visual LISP:
(defun c:Example_NumberOfFaces()
    ;; This example creates a PolyFaceMesh and displays the number of faces it contains
    ;; Data for new PolyFaceMesh object
    (setq vertexList (vlax-make-safearray vlax-vbDouble '(0 . 17)))
    (vlax-safearray-fill vertexList '(4 7 0
				      5 7 0
				      6 7 0
				      4 6 0
				      5 6 0
				      6 6 6
    (setq FaceList (vlax-make-safearray vlax-vbInteger '(0 . 7)))
    (vlax-safearray-fill FaceList '(1
				    2
				    5
				    4
				    2
				    3
				    6
				    5
    ;; Create new PolyFaceMesh object
    (setq NewPolyFaceMeshObj (vla-AddPolyfaceMesh modelSpace vertexList FaceList))
    (vla-Update NewPolyFaceMeshObj)
    ;; Change the viewing direction of the viewport to
    ;; better see the polyface mesh
    (setq direction (vlax-3d-point -1 -1 1))
    (setq activeViewport (vla-get-ActiveViewport doc))
    (vla-put-Direction activeViewport direction)
    (vla-put-ActiveViewport doc activeViewport)
    (vla-ZoomAll acadObj)
    ;; Display number of faces in this PolyFaceMesh
    (alert (strcat "The new PolyFaceMesh contains " (itoa (vla-get-NumberOfFaces NewPolyFaceMeshObj)) " faces."))
GMT+8, 2026-11-12 13:18
