ActiveX 开发指南
相关分类
NumberOfCopyRecords (ActiveX)
2023-1-3 10:15| 发布者: admin| 查看: 2007| 评论: 0|来自: AutoCAD
摘要: 指定要打印的副本数。
指定要打印的副本数。
支持的平台:仅窗口
工 务 局:
object.NumberOfCopies
类型:剧情
此属性适用的对象。
只读:不
类型:长
要打印的副本数。
没有额外的评论。
工 务 局:
Sub Example_NumberOfCopies()
    ' This example plots the layouts of a drawing.
    Dim oPlot As AcadPlot
    Dim AddedLayouts() As String
    Dim LayoutList As Variant
    Dim oLayout As AcadLayout
    Dim ArraySize As Integer, BatchCount As Integer
    For Each oLayout In ThisDrawing.Layouts
        ArraySize = ArraySize + 1
        ReDim Preserve AddedLayouts(1 To ArraySize)
        AddedLayouts(ArraySize) = oLayout.Name
    Next
    LayoutList = AddedLayouts
    Set oPlot = ThisDrawing.Plot
    oPlot.SetLayoutsToPlot LayoutList
    oPlot.PlotToDevice "DWF6 ePlot.pc3"
Visual LISP:
(defun c:Example_NumberOfCopies()
    ;; This example plots the layouts of a drawing.
    (setq AddedLayouts (vlax-make-safearray vlax-vbString (cons 0 (1- (vla-get-Count (vla-get-Layouts doc)))))
          ArraySize 0)
    (vlax-for oLayout (vla-get-Layouts doc)
        (vlax-safearray-put-element AddedLayouts ArraySize (vla-get-Name oLayout))
        (setq ArraySize (1+ ArraySize))
    (setq oPlot (vla-get-Plot doc))
    (vla-SetLayoutsToPlot oPlot AddedLayouts)
    (vla-PlotToDevice oPlot "DWF6 ePlot.pc3")
GMT+8, 2026-11-17 14:41
