确定多行属性的文本边界的宽度。 支持的平台:仅窗口 属性值只读:不 类型:双 文本边界的宽度。 言论没有额外的评论。 例子工 务 局: Sub Example_MTextAttribute()
' This example creates an attribute definition in model space.
' It then manipulates its MText properties
Dim attributeObj As IAcadAttribute
Dim height As Double
Dim mode As Long
Dim prompt As String
Dim tag As String
Dim value As String
' Define the attribute definition
height = 1.4
mode = acAttributeModeVerify
prompt = "New Prompt"
insertionPoint(0) = 5.2: insertionPoint(1) = 5.7: insertionPoint(2) = 0
tag = "NEW_TAG"
value = "New Value"
' Create the attribute definition object in model space
Set attributeObj = ThisDrawing.ModelSpace.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
attributeObj.MTextAttribute = True
attributeObj.MTextAttributeContent = "test content"
attributeObj.MTextBoundaryWidth = 4.2
attributeObj.UpdateMTextAttribute
ZoomAll
Visual LISP: (vl-load-com)
(defun c:Example_MTextAttribute()
;; This example creates an attribute definition in model space.
;; It then manipulates its MText properties
;; Define the attribute definition
(setq insertionPoint (vlax-3d-point 5.2 5.7 0)
attHeight 1.4
attMode (+ acAttributeModeVerify acAttributeModeMultipleLine)
attPrompt "New Prompt"
attTag "NEW_TAG"
attValue "New Value")
;; Create the attribute definition object in model space
(setq attributeObj (vla-AddAttribute modelSpace attHeight attMode attPrompt insertionPoint attTag attValue))
(vla-put-MTextAttributeContent attributeObj "test content")
(vla-put-MTextBoundaryWidth attributeObj 4.2)
(vla-UpdateMTextAttribute attributeObj)
(vla-ZoomAll acadObj)
GMT+8, 2026-10-30 07:03
