获取实体的惯性矩。 支持的平台:仅窗口 属性值只读:是的 类型:变体(双精度的三元素数组) 基于当前坐标系的 3D 坐标。 言论惯性矩返回为定义为变体的X、Y 和Z坐标。 例子工 务 局: Sub Example_MomentOfInertia()
' This example creates a box in model space.
' It then returns the MomentOfInertia for that box.
Dim boxObj As Acad3DSolid
Dim length As Double, width As Double, height As Double
Dim center(0 To 2) As Double
' Define the box
center(0) = 5#: center(1) = 5#: center(2) = 0
length = 5#: width = 7: height = 10#
' Create the box (3DSolid) object in model space
Set boxObj = ThisDrawing.ModelSpace.AddBox(center, length, width, height)
' Change the viewing direction of the viewport to better see the box
Dim NewDirection(0 To 2) As Double
NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
ThisDrawing.ActiveViewport.direction = NewDirection
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
ZoomAll
' Return the MomentOfInertia for the box
Dim momentOfInertia As Variant
momentOfInertia = boxObj.momentOfInertia
MsgBox "The MomentOfInertia for the box is " & momentOfInertia(0) & ", " & momentOfInertia(1) & ", " & momentOfInertia(2), , "MomentOfInertia Example"
Visual LISP: (vl-load-com)
(defun c:Example_MomentOfInertia()
;; This example creates a box in model space.
;; It then returns the MomentOfInertia for that box.
;; Define the box
(setq center (vlax-3d-point 5 5 0)
boxLength 5
boxWidth 7
boxHeight 10)
;; Create the box (3DSolid) object in model space
(setq boxObj (vla-AddBox modelSpace center boxLength boxWidth boxHeight))
;; Change the viewing direction of the viewport to better see the box
(setq NewDirection (vlax-3d-point -1 -1 1))
(setq activeViewport (vla-get-ActiveViewport doc))
(vla-put-Direction activeViewport NewDirection)
(vla-put-ActiveViewport doc activeViewport)
(vla-ZoomAll acadObj)
;; Return the MomentOfInertia for the box
(setq momentOfInertia (vlax-variant-value (vla-get-MomentOfInertia boxObj)))
(alert (strcat "The MomentOfInertia for the box is " (rtos (vlax-safearray-get-element momentOfInertia 0) 2) ", "
(rtos (vlax-safearray-get-element momentOfInertia 1) 2) ", "
(rtos (vlax-safearray-get-element momentOfInertia 2) 2)))
GMT+8, 2026-10-31 21:23
