ActiveX 开发指南
相关分类
菜单组属性 (ActiveX)
2023-1-3 11:02| 发布者: admin| 查看: 1630| 评论: 0|来自: AutoCAD
摘要: 获取会话的菜单组集合。
获取会话的菜单组集合。
支持的平台:仅窗口
工 务 局:
object.MenuGroups
类型:应用
此属性适用的对象。
只读:是的
类型:菜单组
会话的集合。MenuGroups
没有额外的评论。
工 务 局:
Sub Example_MenuGroups()
    ' This example uses MenuGroups to obtain a reference to the AutoCAD main menu.
    ' It then creates a new menu called TestMenu and inserts a menu item
    ' into it. The menu is then displayed on the menu bar.
    ' The menu item will be automatically removed when AutoCAD is restarted
    Dim currMenuGroup As acadMenuGroup
    Dim newMenu As AcadPopupMenu, newMenuItem As AcadPopupMenuItem
    Dim openMacro As String
    On Error GoTo ERRORTRAP
    ' Use MenuGroups property to obtain reference to main AutoCAD menu
    Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item("ACAD")
    ' Create the new menu in this group
    Set newMenu = currMenuGroup.Menus.Add("TestMenu")
    ' Add a menu item to the new menu and
    ' assign an Open macro (VBA equivalent of: "ESC ESC _open ")
    openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
    Set newMenuItem = newMenu.AddMenuItem(newMenu.count + 1, "Open", openMacro)
    ' Display the menu on the menu bar
    newMenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.count + 1)
    MsgBox "A new menu has been added to the ACAD menu system!"
    Exit Sub
ERRORTRAP:
    MsgBox "The following error has occurred: " & Err.Description
Visual LISP:
(defun c:Example_MenuGroups()
    ;; This example uses MenuGroups to obtain a reference to the AutoCAD main menu.
    ;; It then creates a new menu called TestMenu and inserts a menu item
    ;; into it. The menu is then displayed on the menu bar.
    ;; The menu item will be automatically removed when AutoCAD is restarted
    ;; Use MenuGroups property to obtain reference to main AutoCAD menu
    (setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) "ACAD"))
    ;; Create the new menu in this group
    (setq newMenu (vla-Add (vla-get-Menus currMenuGroup) "TestMenu"))
    ;; Add a menu item to the new menu and
    ;; assign an Open macro (VBA equivalent of: "ESC ESC _open ")
    (setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
    (setq newMenuItem (vla-AddMenuItem newMenu (1+ (vla-get-Count newMenu)) "Open" openMacro))
    ;; Display the menu on the menu bar
    (vla-InsertInMenuBar newMenu (1+ (vla-get-Count (vla-get-MenuBar acadObj))))
    (alert "A new menu has been added to the ACAD menu system!")
GMT+8, 2026-9-15 22:35
