获取维度的度量值。 支持的平台:仅窗口 属性值只读:是的 类型:双 对于线性尺寸,这是一个长度,对于角度尺寸,它是一个角度。 言论对于非角度尺寸,此属性将覆盖 DIMLUNIT 系统变量的值。 对于角度尺寸,此属性将覆盖 DIMAUNIT 系统变量的值。 例子工 务 局: Sub Example_Measurement()
' This example creates an aligned dimension in model space
' and returns the measurement of the dimension; in the case
' of a linear dimension, this measurement will be its length
Dim dimObj As AcadDimAligned
Dim CurrentValue As String
' Define the dimension
point2(0) = 9: point2(1) = 5: point2(2) = 0
' Read and display current measurement
MsgBox "The current measurement of the new dimension is: " & dimObj.Measurement
Visual LISP: (vl-load-com)
(defun c:Example_Measurement()
;; This example creates an aligned dimension in model space
;; and returns the measurement of the dimension; in the case
;; of a linear dimension, this measurement will be its length
;; Define the dimension
point2 (vlax-3d-point 9 5 0)
(vla-ZoomAll acadObj)
;; Read and display current measurement
(alert (strcat "The current measurement of the new dimension is: " (rtos (vla-get-Measurement dimObj) 2)))
GMT+8, 2026-11-7 13:56
