ActiveX 开发指南
相关分类
掩码属性 (ActiveX)
2023-1-3 11:22| 发布者: admin| 查看: 1705| 评论: 0|来自: AutoCAD
摘要: 指定要恢复的图层属性。
指定要恢复的图层属性。
支持的平台:仅窗口
工 务 局:
object.Mask
类型:层状态管理器
此属性适用的对象。
只读:
类型:枚举AcLayerStateMask
表示要恢复的图层属性的数字。使用下表中的常量标识图层属性:
  • acLsAll:所有图层属性
  • acLsColor:颜色
  • acLsFrozen:冷冻或解冻
  • acLsLineType:线型
  • acLsLineWeight:线宽
  • acLsLocked:锁定或解锁
  • acLsNewViewport:冻结或解冻的新视口图层
  • acLsNone:没有
  • acLsOn:开或关
  • acLsPlot:打印打开或关闭
  • acLsPlotStyle:绘图风格
方法使用 Mask 属性来标识要还原的图层属性。首先在使用 LayerStateManager 方法保存图层设置时设置该属性。但是,Save 方法实际上保存每个绘图图层的所有属性。您可以在恢复图层设置之前随时更新属性,从而更改要恢复的图层属性。RestoreMaskSaveMask
要在蒙版中指定多个图层属性,请添加表示这些属性的常量。例如,要保存“颜色”和“线型”属性,请指定以下内容:
acLsColor + acLsLineType
工 务 局:
Sub Example_SetMask()
    ' The following code updates the Mask property of layer
    ' settings saved under the name "ColorLineType, so that
    ' Color, LineType, and LineWeight layer properties will
    ' be restored by a Restore operation.
    Dim oLSM As AcadLayerStateManager
    Dim settings As AcLayerStateMask
    Set oLSM = ThisDrawing.Application. _
       GetInterfaceObject("AutoCAD.AcadLayerStateManager." & Left(AcadApplication.Version, 2))
    oLSM.SetDatabase ThisDrawing.Database
    oLSM.Save "ColorLinetype", acLsColor + acLsLineType
    ' Retrieve the current mask setting from ColorLinetype
    settings = oLSM.Mask("ColorLinetype")
    ' Set mask so that Color, LineType, and LineWeight
    ' properties will be restored by a Restore operation
    settings = acLsColor + acLsLineType + acLsLineWeight
    ' Commit the new settings mask to ColorLinetype
    oLSM.Mask("ColorLinetype") = settings
Visual LISP:
(defun c:Example_Mask()
    ;; The following code updates the Mask property of layer
    ;; settings saved under the name "ColorLineType, so that
    ;; Color, LineType, and LineWeight layer properties will
    ;; be restored by a Restore operation.
    (setq oLSM (vla-GetInterfaceObject acadObj (strcat "AutoCAD.AcadLayerStateManager." (substr (getvar "ACADVER") 1 2))))
    (vla-SetDatabase oLSM (vla-get-Database doc))
    (vla-Save oLSM "ColorLinetype" (+ acLsColor acLsLineType))
    ;; Retrieve the current mask setting from ColorLinetype
    (setq settings (vla-get-Mask oLSM "ColorLinetype"))
    ;; Set mask so that Color, LineType, and LineWeight
    ;; properties will be restored by a Restore operation
    (setq settings (+ acLsColor acLsLineType acLsLineWeight))
    ;; Commit the new settings mask to ColorLinetype
    (vla-put-Mask oLSM "ColorLinetype" settings)
    (vlax-release-object oLSM)
GMT+8, 2026-9-15 21:23
