指定 MText 对象的行距样式。 支持的平台:仅窗口 属性值只读:不 类型:枚举acLineSpacingStyle
言论该设置允许根据文本行中最大字符的高度自动调整不同文本行之间的间距。该设置强制对象中所有行的行间距为相同的大小,而不考虑格式覆盖。acLineSpacingStyleAtLeastacLineSpacingStyleExactlyMText 例子工 务 局: Sub Example_LineSpacingFactor()
' This example creates an MText object in model space
' and then finds the LineSpacingFactor for the object.
Dim MTextObj As AcadMText
Dim corner(0 To 2) As Double
Dim width As Double
Dim text As String
corner(0) = 0#: corner(1) = 10#: corner(2) = 0#
width = 10
text = "This is the text String for the mtext Object"
' Creates the MText Object
Set MTextObj = ThisDrawing.ModelSpace.AddMText(corner, width, text)
ZoomAll
' Find the current LineSpacingFactor
Dim currFactor As Double
currFactor = MTextObj.LineSpacingFactor
MsgBox "The LineSpacingFactor for the MText object is: " & currFactor
' Change the LineSpacingFactor
MTextObj.LineSpacingFactor = 4
MsgBox "The LineSpacingFactor for the MText object is: " & MTextObj.LineSpacingFactor
' Reset the LineSpacingFactor
MTextObj.LineSpacingFactor = currFactor
Visual LISP: (vl-load-com)
(defun c:Example_LineSpacingFactor()
;; This example creates an MText object in model space
;; and then finds the LineSpacingFactor for the object.
(setq corner (vlax-3d-point 0 10 0)
width 10
text "This is the text String for the mtext Object")
;; Creates the MText Object
(setq MTextObj (vla-AddMText modelSpace corner width text))
(vla-ZoomAll acadObj)
;; Find the current LineSpacingFactor
(setq currFactor (vla-get-LineSpacingFactor MTextObj))
(alert (strcat "The LineSpacingFactor for the MText object is: " (rtos currFactor 2)))
;; Change the LineSpacingFactor
(vla-put-LineSpacingFactor MTextObj 0.7)
(alert (strcat "The LineSpacingFactor for the MText object is: " (rtos (vla-get-LineSpacingFactor MTextObj) 2)))
;; Reset the LineSpacingFactor
(vla-put-LineSpacingFactor MTextObj currFactor)
GMT+8, 2026-11-2 12:12
