ActiveX 开发指南
相关分类
长度属性 (ActiveX)
2023-1-3 12:10| 发布者: admin| 查看: 1569| 评论: 0|来自: AutoCAD
摘要: 获取对象的长度。
获取对象的长度。
支持的平台:仅窗口
工 务 局:
object.Length
类型:3D线,线,LW线,点云,折线,扫描面
此属性适用的对象。
只读:是的
类型:双
行的长度。
没有额外的评论。
工 务 局:
Sub Example_Length()
   ' This example adds a line in model space and returns the length of the new line
    Dim lineObj As AcadLine
    Dim startPoint(0 To 2) As Double, endPoint(0 To 2)  As Double
    ' Define the start and end points for the line
    startPoint(0) = 1: startPoint(1) = 1: startPoint(2) = 0
    endPoint(0) = 5: endPoint(1) = 5: endPoint(2) = 0
    ' Create the line in model space
    MsgBox "The length of the new Line is: " & lineObj.length
Visual LISP:
(defun c:Example_Length()
    ;; This example adds a line in model space and returns the length of the new line
    ;; Define the start and end points for the line
    (setq startPoint (vlax-3d-point 1 1 0)
          endPoint (vlax-3d-point 5 5 0))
    ;; Create the line in model space
    (vla-ZoomAll acadObj)
    (alert (strcat "The length of the new Line is: " (rtos (vla-get-Length lineObj) 2)))
GMT+8, 2026-10-27 09:10
