ActiveX 开发指南
相关分类
LayoutDisplayPaperShadow Property (ActiveX)
2023-1-3 12:33| 发布者: admin| 查看: 1832| 评论: 0|来自: AutoCAD
摘要: 切换布局中纸张背景阴影的显示。
切换布局中纸张背景阴影的显示。
支持的平台:仅窗口
工 务 局:
object.LayoutDisplayPaperShadow
类型:首选项显示
此属性适用的对象。
只读:不
类型:布尔
  • True:阴影显示在布局中。
  • False:阴影不显示在布局中。
此属性的初始值为。True
工 务 局:
Sub Example_LayoutDisplayPaperShadow()
    ' This example reads and modifies the preference value that controls
    ' the display of the paper background shadow in layouts. When finished, this example
    ' resets the preference value back to its original value.
    Dim ACADPref As AcadPreferencesDisplay
    ' Get the display preferences object
    Set ACADPref = ThisDrawing.Application.preferences.DISPLAY
    ' Switch to paper space to view this change
    ThisDrawing.ActiveSpace = acPaperSpace
    originalValue = ACADPref.LayoutDisplayPaperShadow
    MsgBox "The LayoutDisplayPaperShadow preference is set to: " & originalValue
    ' Modify the LayoutDisplayPaperShadow preference by toggling the value
    ACADPref.LayoutDisplayPaperShadow = Not (originalValue)
    newValue = ACADPref.LayoutDisplayPaperShadow
    MsgBox "The LayoutDisplayPaperShadow preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.LayoutDisplayPaperShadow = originalValue
    MsgBox "The LayoutDisplayPaperShadow preference was reset back to: " & originalValue
Visual LISP:
(defun c:Example_LayoutDisplayPaperShadow()
    ;; This example reads and modifies the preference value that controls
    ;; the display of the paper background shadow in layouts. When finished, this example
    ;; resets the preference value back to its original value.
    ;; Switch to paper space to view this change
    (vla-put-ActiveSpace doc acPaperSpace)
    (setq originalValue (vla-get-LayoutDisplayPaperShadow (vla-get-Display preferences)))
    (alert (strcat "The LayoutDisplayPaperShadow preference is set to: " (if (= originalValue :vlax-true) "True"  "False")))
    ;; Modify the LayoutDisplayPaperShadow preference by toggling the value
    (vla-put-LayoutDisplayPaperShadow (vla-get-Display preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-LayoutDisplayPaperShadow (vla-get-Display preferences)))
    (alert (strcat "The LayoutDisplayPaperShadow preference has been set to: " (if (= newValue :vlax-true) "True"  "False")))
    ;;         this preference in effect
    (vla-put-LayoutDisplayPaperShadow (vla-get-Display preferences) originalValue)
    (alert (strcat "The LayoutDisplayPaperShadow preference was reset back to: " (if (= originalValue :vlax-true) "True"  "False")))
GMT+8, 2026-10-30 07:03
