指定外部参照或视口是否具有图层特性覆盖。 支持的平台:仅窗口 属性值只读:是的 类型:布尔
言论对象从中继承此属性,但此属性在使用时不会影响该类型的对象。ComparedReferenceExternalReferenceComparedReference 例子工 务 局: Sub Example_LayerPropertyOverrides()
' This example checks to see if the viewports in Paper Space
' have one or more layer property overrides applied.
Dim acObj As AcadObject
' Step through the objects in Paper space
For Each acObj In ThisDrawing.PaperSpace
' Check to see if the object is a Viewport
If acObj.ObjectName = "AcDbViewport" Then
' Display the Layer Properties Override status for the viewport
GoSub DISPLAYSTATUS
End If
Next acObj
Exit Sub
DISPLAYSTATUS:
Dim vpObj As AcadPViewport
Set vpObj = acObj
' Get the ObjectId for the viewport
Dim strObjId as string
strObjId = "ObjectId: " + CStr(vpObj.ObjectId)
' Display a message based on whether the viewport has layer overrides applied
If vpObj.LayerPropertyOverrides Then
MsgBox strObjId + vbLf + "Viewport does have layer property overrides applied.", , "LayerPropertyOverrides Example"
Else
MsgBox strObjId + vbLf + "Viewport doesn't have any layer property overrides applied.", , "LayerPropertyOverrides Example"
End If
Return
Visual LISP: (vl-load-com)
(defun c:Example_LayerPropertyOverrides()
;; This example checks to see if the viewports in Paper Space
;; have one or more layer property overrides applied.
;; Step through the objects in Paper space
(vlax-for acObj (vla-get-PaperSpace doc)
;; Check to see if the object is a Viewport
(if (= (vla-get-ObjectName acObj) "AcDbViewport")
(progn
;; Get the ObjectId for the viewport
(setq strObjId (strcat "ObjectID: " (itoa (vla-get-ObjectId acObj))))
;; Display a message based on whether the viewport has layer overrides applied
(if (= (vla-get-LayerPropertyOverrides acObj) :vlax-true)
(alert (strcat strObjId
"\nViewport does have layer property overrides applied."))
"\nViewport doesn't have any layer property overrides applied."))
GMT+8, 2026-10-30 07:03
