ActiveX 开发指南
相关分类
图层属性 (ActiveX)
2023-1-3 12:52| 发布者: admin| 查看: 3527| 评论: 0|来自: AutoCAD
摘要: 指定对象的图层。
指定对象的图层。
支持的平台:仅窗口
工 务 局:
object.Layer
类型:所有图形对象,属性引用,组,子DMeshEdge,SubDMeshFace,SubDMeshVertex,SubEntity,SubEntSolidEdge,SubEntSolidFace,SubEntSolidNode,SubEntSolidVertex
此属性适用的对象。
只读:不;除了只写的对象Group
类型:字符串
图层的名称。
所有对象都有一个关联的图层。文档始终包含至少一个图层(图层 0)。与线型一样,您可以为对象指定图层。如果未指定图层,则当前活动图层将用于新对象。如果为对象指定了图层,则忽略当前活动图层。使用该属性设置或查询当前活动图层。ActiveLayer
每个图层都有关联的属性,可以通过对象设置和查询这些属性。Layer
工 务 局:
Sub Example_Layer()
    ' This example creates a new layer named "ABC" (colored blue).
    ' It then creates a circle and assigns it to layer "ABC"
    ' Create new layer
    Dim layerObj As AcadLayer
    Set layerObj = ThisDrawing.Layers.Add("ABC")
    Dim color As AcadAcCmColor
	   Set color = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(AcadApplication.Version, 2))
    Call color.SetRGB(80, 100, 244)
    layerObj.TrueColor = color
    ' Create Circle
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 3: center(1) = 3: center(2) = 0
    radius = 1.5
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(center, radius)
    ZoomAll
    MsgBox "The circle has been created on layer " & circleObj.Layer, , "Layer Example"
    ' Set the layer of new circle to "ABC"
    circleObj.Layer = "ABC"
    ' Refresh view
    ThisDrawing.Regen (True)
    MsgBox "The circle is now on layer " & circleObj.Layer, , "Layer Example"
Visual LISP:
(defun c:Example_Layer()
    ;; This example creates a new layer named "ABC" (colored blue).
    ;; It then creates a circle and assigns it to layer "ABC"
    ;; Create new layer
    (setq layerObj (vla-Add (vla-get-Layers doc) "ABC"))
    (setq color (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2))))
    (vla-SetRGB color 80 100 244)
    (vla-put-TrueColor layerObj color)
    ;; Create Circle
    (setq center (vlax-3d-point 3 3 0)
          radius 1.5)
    (setq circleObj (vla-AddCircle modelSpace center radius))
    (vla-ZoomAll acadObj)
    (alert (strcat "The circle has been created on layer " (vla-get-Layer circleObj)))
    ;; Set the layer of new circle to "ABC"
    (vla-put-Layer circleObj "ABC")
    ;; Refresh view
    (vla-Regen doc :vlax-true)
    (alert (strcat "The circle is now on layer " (vla-get-Layer circleObj)))
    (vlax-release-object color)
GMT+8, 2026-11-8 04:34
