ActiveX 开发指南
相关分类
大按钮属性 (ActiveX)
2023-1-3 12:57| 发布者: admin| 查看: 1694| 评论: 0|来自: AutoCAD
摘要: 指定工具栏按钮是大还是小。
指定工具栏按钮是大还是小。
支持的平台:仅窗口
工 务 局:
object.LargeButtons
类型:工具栏,工具栏
此属性适用的对象。
只读:是的;除了可读写的集合Toolbars
类型:布尔
  • True:工具栏很大。
  • False:工具栏很小。
没有额外的评论。
工 务 局:
Sub Example_LargeButtons()
    ' This example uses MenuGroups to obtain a reference to the AutoCAD main menu.
    ' It then creates a new Toolbar (TestMenu) and inserts a ToolBarButton
    ' into it.  It then sets the LargeButtons property to change the visible style
    ' of all the system Toolbars
    Dim CurrSize As Boolean, ButtonSize As String
    Dim Toolbars As AcadToolbars
    ' Make the system Toolbar buttons bigger
    Set Toolbars = ThisDrawing.Application.MenuGroups("ACAD").Toolbars
    ' Get current size
    CurrSize = Toolbars.LargeButtons
    ' Display current Toolbar size
    GoSub DISPLAY
    ' Toggle Toolbar size
    Toolbars.LargeButtons = Not (Toolbars.LargeButtons)
    GoSub DISPLAY
    ' Reset to original value
    Toolbars.LargeButtons = CurrSize
    GoSub DISPLAY
    Exit Sub
DISPLAY:
    ' Display button style
    ButtonSize = IIf(Toolbars.LargeButtons, "Large", "Normal size")
    MsgBox "We are displaying " & ButtonSize & " buttons.", vbInformation
    Return
Visual LISP:
(defun c:Example_LargeButtons()
    ;; This example uses MenuGroups to obtain a reference to the AutoCAD main menu.
    ;; It then creates a new Toolbar (TestMenu) and inserts a ToolBarButton
    ;; into it.  It then sets the LargeButtons property to change the visible style
    ;; of all the system Toolbars
    ;; Make the system Toolbar buttons bigger
    (setq Toolbars (vla-get-Toolbars (vla-Item (vla-get-MenuGroups acadObj) "ACAD")))
    ;; Get current size
    (setq CurrSize (vla-get-LargeButtons Toolbars))
    ;; Display current Toolbar size
    (setq ButtonSize (if (= CurrSize :vlax-true) "Large" "Normal size"))
    (alert (strcat "We are displaying " ButtonSize " buttons."))
    ;; Toggle Toolbar size
    (vla-put-LargeButtons Toolbars (if (= (vla-get-LargeButtons Toolbars) :vlax-true) :vlax-false :vlax-true))
    (setq ButtonSize (if (= (vla-get-LargeButtons Toolbars) :vlax-true) "Large" "Normal size"))
    ;; Reset to original value
    (vla-put-LargeButtons Toolbars CurrSize)
GMT+8, 2026-10-29 10:27
