控制 AutoCAD 如何响应坐标数据的输入。 支持的平台:仅窗口 属性值只读:不 类型:枚举acKeyboardPriority
言论此属性的初始值为。acKeyboardEntryExceptScripts 注意:此属性的值存储在 OSNAPCOORD 系统变量中。
例子工 务 局: Sub Example_KeyboardPriority()
' KeyboardPriority. It then changes the value, and finally
Dim currKeyboardPriority As Integer
Dim constant As String
Dim newConstant As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current KeyboardPriority value
currKeyboardPriority = preferences.User.KeyboardPriority
constant = Choose(currKeyboardPriority + 1, "acKeyboardRunningObjSnap", "acKeyboardEntry", "acKeyboardEntryExceptScripts")
MsgBox "The current value for KeyboardPriority is " & constant, vbInformation, "KeyboardPriority Example"
' Change the value for KeyboardPriority
newConstant = "acKeyboardEntry"
preferences.User.KeyboardPriority = acKeyboardEntry
MsgBox "The new value for KeyboardPriority is " & newConstant, vbInformation, "KeyboardPriority Example"
' Reset KeyboardPriority to its original value
preferences.User.KeyboardPriority = currKeyboardPriority
MsgBox "The KeyboardPriority value is reset to " & constant, vbInformation, "KeyboardPriority Example"
Visual LISP: (vl-load-com)
(defun c:Example_KeyboardPriority()
;; KeyboardPriority. It then changes the value, and finally
;; Retrieve the current KeyboardPriority value
(setq currKeyboardPriority (vla-get-KeyboardPriority (vla-get-User preferences)))
(setq constant (cond
((= currKeyboardPriority 0) "acKeyboardRunningObjSnap")
((= currKeyboardPriority 1) "acKeyboardEntry")
((= currKeyboardPriority 2) "acKeyboardEntryExceptScripts")))
(alert (strcat "The current value for KeyboardPriority is " constant))
;; Change the value for KeyboardPriority
(setq newConstant "acKeyboardEntry")
(vla-put-KeyboardPriority (vla-get-User preferences) acKeyboardEntry)
(alert (strcat "The new value for KeyboardPriority is " newConstant))
;; Reset KeyboardPriority to its original value
(vla-put-KeyboardPriority (vla-get-User preferences) currKeyboardPriority)
(alert (strcat "The KeyboardPriority value is reset to " constant))
GMT+8, 2026-10-31 21:22
