ActiveX 开发指南
相关分类
IsPeriodic Property (ActiveX)
2023-1-3 13:30| 发布者: admin| 查看: 1890| 评论: 0|来自: AutoCAD
摘要: 确定给定样条曲线是否为周期性样条曲线。
确定给定样条曲线是否为周期性样条曲线。
支持的平台:仅窗口
工 务 局:
object.IsPeriodic
类型:样条
此属性适用的对象。
只读:是的
类型:布尔
  • True:样条是周期性的。
  • False:样条曲线不是周期性的。
没有额外的评论。
工 务 局:
Sub Example_IsPeriodic()
    ' This example creates a Spline object in model space and
    ' determines if the Spline is periodic
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double, endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    Dim UserMessage As String
    ' Define the Spline object
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    fitPoints(0) = 0: fitPoints(1) = 0: fitPoints(2) = 0: fitPoints(3) = 5
    fitPoints(4) = 5: fitPoints(5) = 0: fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
    ' Create new Spline object
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ' Display whether or not new Spline is periodic
    UserMessage = IIf(splineObj.IsPeriodic, "is periodic", "is not periodic")
    MsgBox "The new Spline " & UserMessage
Visual LISP:
(defun c:Example_IsPeriodic()
    ;; This example creates a Spline object in model space and
    ;; determines if the Spline is periodic
    ;; Define the Spline object
    (setq startTan (vlax-3d-point 0.5 0.5 0)
          endTan (vlax-3d-point 0.5 0.5 0)
          fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill fitPoints '(0 0 0
				     5 5 0
				     10 0 0
    ;; Create new Spline object
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomAll acadObj)
    ;; Display whether or not new Spline is periodic
    (setq UserMessage (if (= (vla-get-IsPeriodic splineObj) :vlax-true) "is periodic" "is not periodic"))
    (alert (strcat "The new Spline " UserMessage))
GMT+8, 2026-11-2 11:06
