公差、文本、块或形状的插入点,以及 OLE 对象的原点(左上角)。 支持的平台:仅窗口 签名工 务 局: object.InsertionPoint 属性值只读:不 类型:变体(双精度的三元素数组) 表示插入点或原点的 3D WCS 坐标。 言论MText:指定文本边界一角的位置。使用该属性指定文本边界的哪个角要定位在此插入点。AttachmentPoint 文本:此属性是只读的,但文本除外,该属性设置为 ,或。若要定位对齐方式不是左对齐、对齐或适合的文本,请使用 theproperty 。AlignmentacAlignmentLeftacAlignmentAlignedacAlignmentFitTextAlignmentPoint 例子工 务 局: Sub Example_InsertionPoint()
' This example creates a text object in model space.
' It then changes the insertion point of the text object.
Dim textObj As AcadText
Dim textString As String
Dim height As Double
' Define the text object
textString = "Hello, World."
insertionPoint(0) = 2: insertionPoint(1) = 2: insertionPoint(2) = 0
height = 0.5
' Create the text object in model space
Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, height)
ZoomAll
' Return the current value of the insertion point
Dim currInsertionPoint As Variant
currInsertionPoint = textObj.insertionPoint
MsgBox "The insertion point of the text is " & currInsertionPoint(0) & ", " & currInsertionPoint(1) & ", " & currInsertionPoint(2), vbInformation, "InsertionPoint Example"
' Change the insertion point of the text object and
' update the display of the text object.
insertionPoint(0) = 3: insertionPoint(1) = 3: insertionPoint(2) = 0
textObj.insertionPoint = insertionPoint
textObj.Update
MsgBox "The new insertion point of the text is " & textObj.insertionPoint(0) & ", " & textObj.insertionPoint(1) & ", " & textObj.insertionPoint(2), vbInformation, "InsertionPoint Example"
Visual LISP: (vl-load-com)
(defun c:Example_InsertionPoint()
;; This example creates a text object in model space.
;; It then changes the insertion point of the text object.
;; Define the text object
(setq textString "Hello, World."
insertionPoint (vlax-3d-point 2 2 0)
height 0.5)
;; Create the text object in model space
(setq textObj (vla-AddText modelSpace textString insertionPoint height))
(vla-ZoomAll acadObj)
;; Return the current value of the insertion point
(setq currInsertionPoint (vlax-safearray->list (vlax-variant-value (vla-get-InsertionPoint textObj))))
(alert (strcat "The insertion point of the text is " (rtos (nth 0 currInsertionPoint) 2) ", "
(rtos (nth 1 currInsertionPoint) 2) ", "
(rtos (nth 2 currInsertionPoint) 2)))
;; Change the insertion point of the text object and
;; update the display of the text object.
(setq insertionPoint (vlax-3d-point 3 3 0))
(vla-put-insertionPoint textObj insertionPoint)
(vla-Update textObj)
(setq newInsertionPoint (vlax-safearray->list (vlax-variant-value (vla-get-InsertionPoint textObj))))
(alert (strcat "The new insertion point of the text is " (rtos (nth 0 newInsertionPoint) 2) ", "
(rtos (nth 1 newInsertionPoint) 2) ", "
(rtos (nth 2 newInsertionPoint) 2)))
GMT+8, 2026-10-29 01:50
