切换超链接光标和快捷菜单的显示。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。True 启用此属性后,每当光标位于包含超链接的对象上时,用户都会看到一个小位图(十字准线的正下方和右侧)。禁用该属性时,将不会显示此位图。 例子工 务 局: Sub Example_HyperlinkDisplayCursor()
' This example reads and modifies the preference value that controls
' the display of the hyperlink cursor and shortcut menu.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesUser
' Get the user preferences object
Set ACADPref = ThisDrawing.Application.preferences.User
originalValue = ACADPref.HyperlinkDisplayCursor
MsgBox "The HyperlinkDisplayCursor preference is set to: " & originalValue
' Modify the HyperlinkDisplayCursor preference by toggling the value
ACADPref.HyperlinkDisplayCursor = Not (ACADPref.HyperlinkDisplayCursor)
newValue = ACADPref.HyperlinkDisplayCursor
MsgBox "The HyperlinkDisplayCursor preference has been set to: " & newValue
' this preference in effect
ACADPref.HyperlinkDisplayCursor = originalValue
MsgBox "The HyperlinkDisplayCursor preference was reset back to: " & originalValue
Visual LISP: (vl-load-com)
(defun c:Example_HyperlinkDisplayCursor()
;; This example reads and modifies the preference value that controls
;; the display of the hyperlink cursor and shortcut menu.
;; When finished, this example resets the preference value back to
;; its original value.
(setq originalValue (vla-get-HyperlinkDisplayCursor (vla-get-User preferences)))
(alert (strcat "The HyperlinkDisplayCursor preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the HyperlinkDisplayCursor preference by toggling the value
(vla-put-HyperlinkDisplayCursor (vla-get-User preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-HyperlinkDisplayCursor (vla-get-User preferences)))
(alert (strcat "The HyperlinkDisplayCursor preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-HyperlinkDisplayCursor (vla-get-User preferences) originalValue)
(alert (strcat "The HyperlinkDisplayCursor preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-11-10 14:28
