指定尺寸文本的水平对齐。 支持的平台:仅窗口 属性值只读:不 类型:枚举acDimHorizontalJustification
言论注意:此属性将覆盖给定维度的 DIMJUST 系统变量的值。
例子工 务 局: Sub Example_HorizontalTextPosition()
' This example creates an aligned dimension in model space
' and cycles the dimension text through different
' horizontal alignments
Dim dimObj As AcadDimAligned
Dim CurrentValue As String
' Define the dimension
point2(0) = 9: point2(1) = 5: point2(2) = 0
' Read and display current text position
Select Case dimObj.HorizontalTextPosition
Case acHorzCentered: CurrentValue = "centered"
Case acFirstExtensionLine: CurrentValue = "aligned to first extension line"
Case acSecondExtensionLine: CurrentValue = "aligned to second extension line"
Case acOverFirstExtension: CurrentValue = "aligned over first extension line"
Case acOverSecondExtension: CurrentValue = "aligned over second extension line"
End Select
MsgBox "The dimension is " & CurrentValue
' Force the alignment of the dimension text to the first extension line
dimObj.HorizontalTextPosition = acFirstExtensionLine
MsgBox "Dimension text is now aligned to the first extension line"
' Force the alignment of the dimension text to the second extension line
dimObj.HorizontalTextPosition = acSecondExtensionLine
MsgBox "Dimension text is now aligned to the second extension line"
Visual LISP: (vl-load-com)
(defun c:Example_HorizontalTextPosition()
;; This example creates an aligned dimension in model space
;; and cycles the dimension text through different
;; horizontal alignments
;; Define the dimension
point2 (vlax-3d-point 9 5 0)
(vla-ZoomAll acadObj)
;; Read and display current text position
(cond
((= (vla-get-HorizontalTextPosition dimObj) acHorzCentered) (setq CurrentValue "centered"))
((= (vla-get-HorizontalTextPosition dimObj) acFirstExtensionLine) (setq CurrentValue "aligned to first extension line"))
((= (vla-get-HorizontalTextPosition dimObj) acSecondExtensionLine) (setq CurrentValue "aligned to second extension line"))
((= (vla-get-HorizontalTextPosition dimObj) acOverFirstExtension) (setq CurrentValue "aligned over first extension line"))
((= (vla-get-HorizontalTextPosition dimObj) acOverSecondExtension) (setq CurrentValue "aligned over second extension line"))
(alert (strcat "The dimension is " CurrentValue))
;; Force the alignment of the dimension text to the first extension line
(vla-put-HorizontalTextPosition dimObj acFirstExtensionLine)
(alert "Dimension text is now aligned to the first extension line")
;; Force the alignment of the dimension text to the second extension line
(vla-put-HorizontalTextPosition dimObj acSecondExtensionLine)
(alert "Dimension text is now aligned to the second extension line")
GMT+8, 2026-10-27 23:00
