指定真彩色的绿色分量。 支持的平台:仅窗口 属性值只读:是的 类型:长 绿色分量,从 0-255,的。AcCmColor 言论没有额外的评论。 例子工 务 局: Sub Example_Green()
' This example draws a line and returns the RGB values
Dim color As AcadAcCmColor
Set color = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(AcadApplication.Version, 2))
color.SetRGB 80, 100, 244
Dim line As AcadLine
startPoint(0) = 1#: startPoint(1) = 1#: startPoint(2) = 0#
endPoint(0) = 5#: endPoint(1) = 5#: endPoint(2) = 0#
Set line = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint)
ZoomAll
line.TrueColor = color
Dim retcolor As AcadAcCmColor
Set retcolor = line.TrueColor
MsgBox "Red = " & retcolor.Red & vbLf & _
"Green = " & retcolor.Green & vbLf & _
"Blue = " & retcolor.Blue
Visual LISP: (vl-load-com)
(defun c:Example_Green()
;; This example draws a line and returns the RGB values
(setq color (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2))))
(vla-SetRGB color 80 100 244)
(setq startPoint (vlax-3d-point 1 1 0)
endPoint (vlax-3d-point 5 5 0))
(setq line (vla-AddLine modelSpace startPoint endPoint))
(vla-ZoomAll acadObj)
(vla-put-TrueColor line color)
(setq retcolor (vla-get-TrueColor line))
(alert (strcat "Red = " (itoa (vla-get-Red retcolor))
"\nGreen = " (itoa (vla-get-Green retcolor))
"\nBlue = " (itoa (vla-get-Blue retcolor))
(vlax-release-object color)
GMT+8, 2026-11-14 21:49
