指定图纸空间布局的背景色。 支持的平台:仅窗口 属性值只读:不 类型:OLE_COLOR(常量)
言论此属性的初始值是介于 Windows 标准背景色和 Windows 标准活动按钮颜色之间的颜色。 图纸空间窗口由 AutoCAD 中的“布局”选项卡标识。模型空间窗口由“模型”选项卡标识。您可以使用属性更改模型空间窗口的背景颜色。GraphicsWinModelBackgrndColor 例子工 务 局: Sub Example_GraphicsWinLayoutBackgrndColor()
' GraphicsWinLayoutBackgrndColor. It then changes the value, and finally
Dim currGraphicsWinLayoutBackgrndColor As OLE_COLOR
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current GraphicsWinLayoutBackgrndColor value
currGraphicsWinLayoutBackgrndColor = preferences.DISPLAY.GraphicsWinLayoutBackgrndColor
MsgBox "The current value for GraphicsWinLayoutBackgrndColor is " _
& preferences.DISPLAY.GraphicsWinLayoutBackgrndColor, vbInformation, "GraphicsWinLayoutBackgrndColor Example"
' Change the value for GraphicsWinLayoutBackgrndColor
preferences.DISPLAY.GraphicsWinLayoutBackgrndColor = 16
MsgBox "The new value for GraphicsWinLayoutBackgrndColor is " _
' Reset GraphicsWinLayoutBackgrndColor to its original value
preferences.DISPLAY.GraphicsWinLayoutBackgrndColor = currGraphicsWinLayoutBackgrndColor
MsgBox "The GraphicsWinLayoutBackgrndColor value is reset to " _
Visual LISP: (vl-load-com)
(defun c:Example_GraphicsWinLayoutBackgrndColor()
;; GraphicsWinLayoutBackgrndColor. It then changes the value, and finally
;; Set PaperSpace/Layout current
(vla-put-ActiveSpace doc acPaperSpace)
;; Retrieve the current GraphicsWinLayoutBackgrndColor value
(setq currGraphicsWinLayoutBackgrndColor (vlax-variant-change-type (vla-get-GraphicsWinLayoutBackgrndColor (vla-get-Display preferences)) vlax-vbLong))
(alert (strcat "The current value for GraphicsWinLayoutBackgrndColor is " (itoa (vlax-variant-value currGraphicsWinLayoutBackgrndColor))))
;; Change the value for GraphicsWinLayoutBackgrndColor
(vla-put-GraphicsWinLayoutBackgrndColor ACADPref (vlax-make-variant 127 19))
(setq newValue (vlax-variant-change-type (vla-get-GraphicsWinLayoutBackgrndColor ACADPref) vlax-vbLong))
(alert (strcat "The new value for GraphicsWinLayoutBackgrndColor is " (itoa (vlax-variant-value newValue))))
;; Reset GraphicsWinLayoutBackgrndColor to its original value
(vla-put-GraphicsWinLayoutBackgrndColor ACADPref currGraphicsWinLayoutBackgrndColor)
(alert (strcat "The GraphicsWinLayoutBackgrndColor value is reset to " (itoa (vlax-variant-value currGraphicsWinLayoutBackgrndColor))))
GMT+8, 2026-10-27 23:00
