切换全屏跟踪矢量的显示。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。True 注意:此属性的值存储在 TRACKPATH 系统变量中。
例子工 务 局: Sub Example_FullScreenTrackingVector()
' This example reads and modifies the preference value that controls
' the display of full-screen tracking vectors.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesDrafting
' Get the drafting preferences object
Set ACADPref = ThisDrawing.Application.preferences.Drafting
originalValue = ACADPref.FullScreenTrackingVector
MsgBox "The FullScreenTrackingVector preference is set to: " & originalValue
' Modify the FullScreenTrackingVector preference by toggling the value
ACADPref.FullScreenTrackingVector = Not (originalValue)
newValue = ACADPref.FullScreenTrackingVector
MsgBox "The FullScreenTrackingVector preference has been set to: " & newValue
' this preference in effect
ACADPref.FullScreenTrackingVector = originalValue
MsgBox "The FullScreenTrackingVector preference was reset back to: " & originalValue
Visual LISP: (vl-load-com)
(defun c:Example_FullScreenTrackingVector()
;; This example reads and modifies the preference value that controls
;; the display of full-screen tracking vectors.
;; When finished, this example resets the preference value back to
;; its original value.
;; Get the drafting preferences object
(setq ACADPref (vla-get-Drafting preferences))
(setq originalValue (vla-get-FullScreenTrackingVector ACADPref))
(alert (strcat "The FullScreenTrackingVector preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the FullScreenTrackingVector preference by toggling the value
(vla-put-FullScreenTrackingVector ACADPref (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-FullScreenTrackingVector ACADPref))
(alert (strcat "The FullScreenTrackingVector preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-FullScreenTrackingVector ACADPref originalValue)
(alert (strcat "The FullScreenTrackingVector preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-28 13:17
