ActiveX 开发指南
相关分类
ForceLineInside Property (ActiveX)
2023-1-3 16:15| 发布者: admin| 查看: 1742| 评论: 0|来自: AutoCAD
摘要: 指定是否在延长线之间绘制尺寸线,即使文本放置在延伸线之外。
支持的平台:仅窗口
工 务 局:
object.ForceLineInside
类型:暗三点角度,暗对齐,暗角,暗弧长度,暗直径,暗径向,暗径大,暗旋转
此属性适用的对象。
只读:不
类型:布尔
  • True:当箭头放置在测量点之外时,在测量点之间绘制尺寸线。
  • False:当箭头放置在测量点之外时,请勿在测量点之间绘制尺寸线。
此属性的初始值为。False
对于半径和直径尺寸(当属性设置为 时),此属性在圆或圆弧内绘制尺寸线和箭头,并将文本和引线放在外部。TextInsideFalse
注意:此属性将覆盖给定维度的 DIMTOFL 系统变量的值。
工 务 局:
Sub Example_ForceLineInside()
    ' This example creates an aligned dimension in model space
    ' and toggles dimension lines to be drawn between extension lines
    Dim dimObj As AcadDimAligned
    Dim CurrentValue As String
    ' Define the dimension
    point2(0) = 5.5: point2(1) = 5: point2(2) = 0
    ' Read and display current line suppression information
    CurrentValue = IIf(dimObj.ForceLineInside, "are", "are not")
    MsgBox "Dimension lines " & CurrentValue & " forced between the extension lines"
    ' Force the display of dimension lines between the extension lines
    dimObj.ForceLineInside = True
    MsgBox "Dimension lines are forced between the extension lines"
    ' Do not force the display of dimension lines between the extension lines (default)
    dimObj.ForceLineInside = False
    MsgBox "Dimension lines are not forced between the extension lines"
Visual LISP:
(defun c:Example_ForceLineInside()
    ;; This example creates an aligned dimension in model space
    ;; and toggles dimension lines to be drawn between extension lines
    ;; Define the dimension
          point2 (vlax-3d-point 5.5 5 0)
    (vla-ZoomAll acadObj)
    ;; Read and display current line suppression information
    (setq CurrentValue (if (= (vla-get-ForceLineInside dimObj) :vlax-true) "are" "are not"))
    (alert (strcat "Dimension lines " CurrentValue " forced between the extension lines"))
    ;; Force the display of dimension lines between the extension lines
    (vla-put-ForceLineInside dimObj :vlax-true)
    (alert "Dimension lines are forced between the extension lines")
    ;; Do not force the display of dimension lines between the extension lines (default)
    (vla-put-ForceLineInside dimObj :vlax-false)
    (alert "Dimension lines are not forced between the extension lines")
GMT+8, 2026-10-28 04:47
