ActiveX 开发指南
相关分类
适合性耐受性 (ActiveX)
2023-1-3 16:25| 发布者: admin| 查看: 1815| 评论: 0|来自: AutoCAD
摘要: 使用新的公差值将样条重新拟合到现有点。
使用新的公差值将样条重新拟合到现有点。
支持的平台:仅窗口
工 务 局:
object.FitTolerance
类型:样条
此属性适用的对象。
只读:不
类型:双
拟合容差不能为负数。
如果拟合公差设置为零,则样条将穿过所有拟合点。提供大于零的值允许曲线在指定的公差范围内通过拟合点。
工 务 局:
Sub Example_FitTolerance()
    ' This example creates a spline object in model space.
    ' It then changes the FitTolerance property of that spline.
    ' Create the spline
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double
    Dim endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
    fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
    fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ZoomAll
    ' Find the current FitTolerance value
    Dim currFitTolerance As Double
    currFitTolerance = splineObj.FitTolerance
    MsgBox "The current FitTolerance is " & currFitTolerance, vbInformation, "FitTolerance Example"
    ' Change the fit tolerance value
    splineObj.FitTolerance = 5
    ZoomAll
    MsgBox "The FitTolerance is now " & splineObj.FitTolerance, vbInformation, "FitTolerance Example"
Visual LISP:
(defun c:Example_FitTolerance()
    ;; This example creates a spline object in model space.
    ;; It then changes the FitTolerance property of that spline.
    ;; Create the spline
    (setq startTan (vlax-3d-point 0.5 0.5 0)
          endTan (vlax-3d-point 0.5 0.5 0)
          fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill fitPoints '(1 1 0
				     5 5 0
				     10 0 0
    ;; Create new Spline object
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomAll acadObj)
    ;; Find the current FitTolerance value
    (setq currFitTolerance (vla-get-FitTolerance splineObj))
    (alert (strcat "The current FitTolerance is " (rtos currFitTolerance 2)))
    ;; Change the fit tolerance value
    (vla-put-FitTolerance splineObj 5)
    (alert (strcat "The FitTolerance is now " (rtos (vla-get-FitTolerance splineObj) 2)))
GMT+8, 2026-10-27 16:48
