指定样条曲线的拟合点。 支持的平台:仅窗口 属性值只读:不 类型:变体(双打数组) 表示样条拟合点的三维 WCS 坐标数组。 言论拟合点定义样条曲线的路径。您可以使用属性更改给定拟合点的公差。您可以使用该方法添加适合点。您可以使用该方法删除适合点。可以使用该方法查询拟合点的位置。您可以使用该方法更改给定拟合点的位置。FitToleranceAddFitPointDeleteFitPointGetFitPointSetFitPoint 例子工 务 局: Sub Example_FitPoints()
' This example creates a Spline object in model space, reads the fit points
' of the Spline and then modifies the fit points of the Spline.
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double, endTan(0 To 2) As Double
Dim FPoints(0 To 8) As Double
Dim UserMessage As String
Dim fitPoints As Variant
Dim iCount As Long, iPoint As Integer
Dim NewFP(0 To 2) As Double
' Define the Spline object
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
FPoints(0) = 0: FPoints(1) = 0: FPoints(2) = 0
FPoints(3) = 5: FPoints(4) = 5: FPoints(5) = 0
FPoints(6) = 10: FPoints(7) = 0: FPoints(8) = 0
' Create new Spline object
Set splineObj = ThisDrawing.ModelSpace.AddSpline(FPoints, startTan, endTan)
' Display fit points for this Spline
GoSub DISPLAYPOINTS
' Modify an existing fit point for this Spline
fitPoints(0) = 3
splineObj.fitPoints = fitPoints
' Now add a new fit point
NewFP(0) = 15: NewFP(1) = 4: NewFP(2) = 0
splineObj.AddFitPoint splineObj.NumberOfFitPoints + 1, NewFP
' Display new fit points for this Spline
GoSub DISPLAYPOINTS
Exit Sub
DISPLAYPOINTS:
fitPoints = splineObj.fitPoints
' Display in groups of three
UserMessage = ""
iPoint = 0
For iCount = 0 To UBound(fitPoints) Step 3
iPoint = iPoint + 1
UserMessage = UserMessage & iPoint & ")" & vbTab
UserMessage = UserMessage & fitPoints(iCount)
UserMessage = UserMessage & ", " & fitPoints(iCount + 1)
UserMessage = UserMessage & ", " & fitPoints(iCount + 2)
UserMessage = UserMessage & vbCrLf
Next
MsgBox "The " & splineObj.NumberOfFitPoints & " Spline fit points are: " & vbCrLf & vbCrLf & UserMessage
Return
Visual LISP: (vl-load-com)
(defun c:Example_FitPoints()
;; This example creates a Spline object in model space, reads the fit points
;; of the Spline and then modifies the fit points of the Spline.
;; Define the Spline object
(setq startTan (vlax-3d-point 0.5 0.5 0)
endTan (vlax-3d-point 0.5 0.5 0)
fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill fitPoints '(0 0 0
5 5 0
10 0 0
;; Create new Spline object
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomAll acadObj)
;; Display fit points for this Spline
(setq fitPoints (vlax-variant-value (vla-get-FitPoints splineObj)))
;; Display in groups of three
(setq UserMessage ""
iPoint 0
iCount 0)
(while (>= (vlax-safearray-get-u-bound fitPoints 1) iCount)
(setq iPoint (1+ iPoint))
(setq UserMessage (strcat UserMessage (itoa iPoint) ") "
(rtos (vlax-safearray-get-element fitPoints iCount) 2) ", "
(rtos (vlax-safearray-get-element fitPoints (+ iCount 1)) 2) ", "
(rtos (vlax-safearray-get-element fitPoints (+ iCount 2)) 2) "\n"))
(setq iCount (+ iCount 3))
(alert (strcat "The " (itoa (vla-get-NumberOfFitPoints splineObj)) " Spline fit points are: \n\n" UserMessage))
;; Modify an existing fit point for this Spline
(vlax-safearray-put-element fitPoints 0 3)
(vla-put-FitPoints splineObj fitPoints)
;; Now add a new fit point
(setq NewFP (vlax-3d-point 15 4 0))
(vla-AddFitPoint splineObj (+ (vla-get-NumberOfFitPoints splineObj) 1) NewFP)
;; Display new fit points for this Spline
iPoint 0
iCount 0)
GMT+8, 2026-10-26 09:29
