根据延长线之间的可用间距,指定文本和箭头在延长线内部或外部的位置。 支持的平台:仅窗口 属性值只读:不 类型:枚举acDimFit
言论此属性的初始值为。acBestFit 该属性设置在扩展线内没有空间时移动文本和箭头的优先级。Fit 注意:此属性将覆盖给定维度的 DIMATFIT 系统变量的值。
例子工 务 局: Sub Example_Fit()
' This example creates an aligned dimension in model space
' and cycles the text fit of the dimension to a couple of common values
Dim dimObj As AcadDimAligned
Dim CurrentFit As String
' Define the dimension
point2(0) = 6: point2(1) = 5: point2(2) = 0
' Read and display current dimension line fit information
Select Case dimObj.Fit
Case acTextAndArrows: CurrentFit = "Text and Arrows"
Case acArrowsOnly: CurrentFit = "Arrows Only"
Case acTextOnly: CurrentFit = "Text Only"
Case acBestFit: CurrentFit = "Best Fit"
End Select
MsgBox "The current dimension fit is set to: " & CurrentFit
' Change the fit to arrows only
dimObj.Fit = acArrowsOnly
MsgBox "The dimension fit has been changed to arrows only"
' Change the fit to text only
dimObj.Fit = acTextOnly
MsgBox "The dimension fit has been changed to text only"
Visual LISP: (vl-load-com)
(defun c:Example_Fit()
;; This example creates an aligned dimension in model space
;; and cycles the text fit of the dimension to a couple of common values
;; Define the dimension
point2 (vlax-3d-point 6 5 0)
(vla-ZoomAll acadObj)
;; Read and display current dimension line fit information
(setq CurrentFit (vla-get-Fit dimObj))
(cond
((= acTextAndArrows CurrentFit)(setq CurrentFit "Text and Arrows"))
((= acArrowsOnly CurrentFit)(setq CurrentFit "Arrows Only"))
((= acTextOnly CurrentFit)(setq CurrentFit "Text Only"))
((= acBestFit CurrentFit)(setq CurrentFit "Best Fit"))
(setq CurrentFit (itoa CurrentFit))
(alert (strcat "The current dimension fit is set to: " CurrentFit))
;; Change the fit to arrows only
(vla-put-Fit dimObj acArrowsOnly)
(alert "The dimension fit has been changed to arrows only")
;; Change the fit to text only
(vla-put-Fit dimObj acTextOnly)
(alert "The dimension fit has been changed to text only")
GMT+8, 2026-10-28 23:31
