指定属性的字段长度。 支持的平台:仅窗口 属性值只读:不 类型:整数 属性的字段长度。 言论没有额外的评论。 例子工 务 局: Sub Example_FieldLength()
' This example creates an attribute definition in model space.
' It then queries the initial value of the FieldLength property,
' changes that value, and finally resets the value.
Dim attributeObj As AcadAttribute
Dim height As Double
Dim mode As Long
Dim prompt As String
Dim tag As String
Dim value As String
' Define the attribute definition
height = 1#
mode = acAttributeModeVerify
prompt = "New Prompt"
insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0
tag = "New_Tag"
value = "New Value"
' Create the attribute definition object in model space
Set attributeObj = ThisDrawing.ModelSpace.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
ZoomAll
' Return the current field length of the attribute
Dim currFieldLength As Integer
currFieldLength = attributeObj.FieldLength
MsgBox "The FieldLength of the attribute is " & attributeObj.FieldLength, vbInformation, "FieldLength Example"
' Change the field length
attributeObj.FieldLength = currFieldLength + 2
attributeObj.Update
MsgBox "The new FieldLength of the attribute is " & attributeObj.FieldLength, vbInformation, "FieldLength Example"
' Reset the field length to the original value
attributeObj.Update
MsgBox "The FieldLength of the attribute is reset to " & attributeObj.FieldLength, vbInformation, "FieldLength Example"
Visual LISP: (vl-load-com)
(defun c:Example_FieldLength()
;; This example creates an attribute definition in model space.
;; It then queries the initial value of the FieldLength property,
;; changes that value, and finally resets the value.
;; Define the attribute definition
(setq insertionPoint (vlax-3d-point 5 5 0)
height 1
attMode acAttributeModeVerify
attPrompt "New Prompt"
attTag "NEW_TAG"
attValue "New Value")
;; Create the attribute definition object in model space
(setq attributeObj (vla-AddAttribute modelSpace height attMode attPrompt insertionPoint attTag attValue))
(vla-ZoomAll acadObj)
;; Return the current field length of the attribute
(setq currFieldLength (vla-get-FieldLength attributeObj))
(alert (strcat "The FieldLength of the attribute is " (itoa currFieldLength)))
;; Change the field length
(setq newFieldLength (+ currFieldLength 2))
(vla-put-FieldLength attributeObj newFieldLength)
(vla-Update attributeObj)
(alert (strcat "The new FieldLength of the attribute is " (itoa newFieldLength)))
;; Reset the field length to the original value
(vla-put-FieldLength attributeObj currFieldLength)
(alert (strcat "The FieldLength of the attribute is reset to " (itoa currFieldLength)))
GMT+8, 2026-10-27 13:42
