指定第一条扩展线的端点。 支持的平台:仅窗口 属性值只读:不 类型:变体(双精度的三元素数组) 表示第一条延伸线端点的 3D 坐标。 言论属性包含扩展线的端点。如果给定尺寸不存在延伸线,则这些点将相等。ExtLine1EndPointExtLine2EndPointExtLine1StartPointExtLine2StartPoint ![]() 例子工 务 局: Sub Example_ExtLine1EndPoint()
' This example creates an angular dimension. It then changes
' the location of the ExtLine1EndPoint.
Dim dimObj As AcadDimAngular
Dim angVert(0 To 2) As Double
Dim FirstPoint(0 To 2) As Double
Dim SecondPoint(0 To 2) As Double
Dim TextPoint(0 To 2) As Double
' Define the dimension
angVert(0) = 0#: angVert(1) = 5#: angVert(2) = 0#
FirstPoint(0) = 1#: FirstPoint(1) = 7#: FirstPoint(2) = 0#
SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0#
TextPoint(0) = 3#: TextPoint(1) = 5#: TextPoint(2) = 0#
' Create the angular dimension in model space
Set dimObj = ThisDrawing.ModelSpace.AddDimAngular(angVert, FirstPoint, SecondPoint, TextPoint)
ZoomAll
MsgBox "The current value of ExtLine1EndPoint is " & dimObj.ExtLine1EndPoint(0) & ", " & dimObj.ExtLine1EndPoint(1) & ", " & dimObj.ExtLine1EndPoint(2), vbInformation, "ExtLine1EndPoint Example"
' Change the endpoint of the first extension line
SecondPoint(0) = 0: SecondPoint(1) = 3: SecondPoint(2) = 0
dimObj.ExtLine1EndPoint = SecondPoint
dimObj.Update
' Return the endpoint of the first extension line
' Note that the return value is a Variant
Dim retPnt As Variant
retPnt = dimObj.ExtLine1EndPoint
MsgBox "The new value of ExtLine1EndPoint is " & dimObj.ExtLine1EndPoint(0) & ", " & dimObj.ExtLine1EndPoint(1) & ", " & dimObj.ExtLine1EndPoint(2), vbInformation, "ExtLine1EndPoint Example"
Visual LISP: (vl-load-com)
(defun c:Example_ExtLine1EndPoint()
;; This example creates an angular dimension. It then changes
;; the location of the ExtLine1EndPoint.
;; Define the dimension
(setq AngleVertex (vlax-3d-point 0 5 0)
FirstPoint (vlax-3d-point 1 7 0)
SecondPoint (vlax-3d-point 1 3 0)
TextPoint (vlax-3d-point 3 5 0))
;; Create the angular dimension in model space
(setq dimObj (vla-AddDimAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
(vla-ZoomAll acadObj)
(setq extLineEndPoint (vlax-safearray->list (vlax-variant-value (vla-get-ExtLine1EndPoint dimObj))))
(alert (strcat "The current value of ExtLine1EndPoint is " (rtos (nth 0 extLineEndPoint) 2) ", "
(rtos (nth 1 extLineEndPoint) 2) ", "
(rtos (nth 2 extLineEndPoint) 2)))
;; Change the endpoint of the first extension line
(setq SecondPoint (vlax-3d-point 0 3 0))
(vla-put-ExtLine1EndPoint dimObj SecondPoint)
(vla-Update dimObj)
;; Return the endpoint of the first extension line
;; Note that the return value is a Variant
(setq retPnt (vlax-safearray->list (vlax-variant-value (vla-get-ExtLine1EndPoint dimObj))))
(alert (strcat "The new value of ExtLine1EndPoint is " (rtos (nth 0 retPnt) 2) ", "
(rtos (nth 1 retPnt) 2) ", "
(rtos (nth 2 retPnt) 2)))
GMT+8, 2026-11-4 23:52
