ActiveX 开发指南
相关分类
ExtensionLineColor Property (ActiveX)
2023-1-3 17:07| 发布者: admin| 查看: 1712| 评论: 0|来自: AutoCAD
摘要: 指定尺寸扩展线的颜色。
指定尺寸扩展线的颜色。
支持的平台:仅窗口
工 务 局:
object.ExtensionLineColor
类型:暗三点角度,暗对齐,暗角,暗弧长度,暗坐标,暗旋转
此属性适用的对象。
只读:不
类型:枚举acColor
使用介于 0 到 256 之间的颜色索引号,或此处列出的常量之一:
  • acByBlock
  • acByLayer
  • acRed
  • acYellow
  • acGreen
  • acCyan
  • acBlue
  • acMagenta
  • acWhite
可以将颜色设置为数字索引值,范围从 0 到 256。为标准的七种颜色以及 BYBLOCK 和 BYLAYER 名称提供了常量。
如果使用,AutoCAD 将以默认颜色(白色或黑色,具体取决于您的配置)绘制新对象,直到它们被分组到块中。在图形中插入块时,块中的对象将继承颜色属性的当前设置。acByBlock
如果使用,新对象将采用绘制它们的图层的颜色。acByLayer
注意:此属性覆盖给定维度对象的 DIMCLRE 系统变量的值。
工 务 局:
Sub Example_ExtensionLineColor()
    ' This example creates a Dim3PointAngular object in model space
    ' and changes the extension line color to red using the ExtensionLineColor property
    Dim DimPointAngularObj As AcadDim3PointAngular
    Dim AngleVertex(0 To 2) As Double
    Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
    Dim TextPoint(0 To 2) As Double
    ' Define the new Dim3PointAngular object
    AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
    FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
    SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
    TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
    ' Create the new Dim3PointAngular object in model space
    Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
    ' Read and display current dimension line color
    MsgBox "The extension line color for this object is currently set to: " & DimPointAngularObj.ExtensionLineColor
    ' Change the extension line color
    DimPointAngularObj.ExtensionLineColor = acRed
    ' Read and display current extension line color
    MsgBox "The extension line color for this object is now set to: " & DimPointAngularObj.ExtensionLineColor & " (Red)"
Visual LISP:
(defun c:Example_ExtensionLineColor()
    ;; This example creates a Dim3PointAngular object in model space
    ;; and changes the extension line color to red using the ExtensionLineColor property
    ;; Define the new Dim3PointAngular object
    (setq AngleVertex (vlax-3d-point 0 0 0)
          FirstPoint (vlax-3d-point 2 2 0)
          SecondPoint (vlax-3d-point 1 4 0)
          TextPoint (vlax-3d-point 6 6 0))
    ;; Create the new Dim3PointAngular object in model space
    (setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
    (vla-ZoomAll acadObj)
    ;; Read and display current dimension line color
    (alert (strcat "The extension line color for this object is currently set to: " (itoa (vla-get-ExtensionLineColor DimPointAngularObj))))
    ;; Change the extension line color
    (vla-put-ExtensionLineColor DimPointAngularObj acRed)
    ;; Read and display current extension line color
    (alert (strcat "The extension line color for this object is now set to: " (itoa (vla-get-ExtensionLineColor DimPointAngularObj)) " (Red)"))
GMT+8, 2026-10-27 21:41
