ActiveX 开发指南
相关分类
启用属性 (ActiveX)
2023-1-3 17:40| 发布者: admin| 查看: 1603| 评论: 0|来自: AutoCAD
摘要: 启用弹出菜单项。指定对象的名称。
启用弹出菜单项。指定对象的名称。
支持的平台:仅窗口
工 务 局:
object.Enable
类型:弹出菜单项
此属性适用的对象。
只读:
类型:布尔
  • True:项目已启用。
  • False:项目已禁用。
在下面的示例中,“撤消”和“重做”菜单项处于禁用状态。
工 务 局:
Sub Example_Enable()
    ' This example creates a new menu called TestMenu and inserts two menu items
    ' into it. The second menu item is then disabled.
    ' The menu is displayed on the menu bar.
    ' To remove the menu after execution of this macro, use the Customize Menu
    ' option from the Tools menu.
    Dim currMenuGroup As acadMenuGroup
    Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
    ' Create the new menu
    Dim newMenu As AcadPopupMenu
    Set newMenu = currMenuGroup.Menus.Add("TestMenu")
    ' Add two menu items to the new menu
    Dim MenuEnable As AcadPopupMenuItem
    Dim MenuDisable As AcadPopupMenuItem
    Dim MenuSeparator As AcadPopupMenuItem
    Dim openMacro As String
    ' Assign the macro string the VB equivalent of "ESC ESC _open "
    openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
    Set MenuEnable = newMenu.AddMenuItem(newMenu.count + 1, "OpenEnabled", openMacro)
    Set MenuSeparator = newMenu.AddSeparator("")
    Set MenuDisable = newMenu.AddMenuItem(newMenu.count + 1, "OpenDisabled", openMacro)
    ' Disable the new menu item
    MenuDisable.Enable = False
    ' Display the menu on the menu bar
    newMenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.count + 1)
Visual LISP:
(defun c:Example_Enable()
    ;; This example creates a new menu called TestMenu and inserts two menu items
    ;; into it. The second menu item is then disabled.
    ;; The menu is displayed on the menu bar.
    ;; To remove the menu after execution of this macro, use the Customize Menu
    ;; option from the Tools menu.
    (setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
    ;; Create the new menu
    (setq newMenu (vla-Add (vla-get-Menus currMenuGroup) "TestMenu"))
    ;; Add two menu items to the new menu
    ;; Assign the macro string the VB equivalent of "ESC ESC _open "
    (setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
    (setq MenuEnable (vla-AddMenuItem newMenu (1+ (vla-get-Count newMenu)) "OpenEnabled" openMacro))
    (setq MenuSeparator (vla-AddSeparator newMenu ""))
    (setq MenuDisable (vla-AddMenuItem newMenu (1+ (vla-get-Count newMenu)) "OpenDisabled" openMacro))
    ;; Disable the new menu item
    (vla-put-Enable MenuDisable :vlax-false)
    ;; Display the menu on the menu bar
    (vla-InsertInMenuBar newMenu (1+ (vla-get-Count (vla-get-MenuBar acadObj))))
GMT+8, 2026-9-11 13:09
