ActiveX 开发指南
相关分类
高程模型空间属性 (ActiveX)
2023-1-3 17:43| 发布者: admin| 查看: 1916| 评论: 0|来自: AutoCAD
摘要: 指定模型空间中的高程设置。
指定模型空间中的高程设置。
支持的平台:仅窗口
工 务 局:
object.ElevationModelSpace
类型:数据库,文档
此属性适用的对象。
只读:不
类型:双
模型空间的高程设置。
当前高程是Z值,每当需要 3D 点但仅提供X和Y值时都会使用该值。当前高程在模型空间和图纸空间中分别维护。
工 务 局:
Sub Example_ElevationModelSpace()
    ' This example changes the model space elevation of the current drawing
    ' and then resets it to the original value again.
    Dim currElevation As Double
    currElevation = ThisDrawing.ElevationModelSpace
    MsgBox "The current model space elevation is " & ThisDrawing.ElevationModelSpace, vbInformation, "ElevationModelSpace Example"
    ' Change the elevation
    ThisDrawing.ElevationModelSpace = currElevation + 2
    MsgBox "The new model space elevation is " & ThisDrawing.ElevationModelSpace, vbInformation, "ElevationModelSpace Example"
    ' Reset the elevation to its original value
    MsgBox "The model space elevation is reset to " & ThisDrawing.ElevationModelSpace, vbInformation, "ElevationModelSpace Example"
Visual LISP:
(defun c:Example_ElevationModelSpace()
    ;; This example changes the model space elevation of the current drawing
    ;; and then resets it to the original value again.
    (setq currElevation (vla-get-ElevationModelSpace doc))
    (alert (strcat "The current model space elevation is " (rtos currElevation 2)))
    ;; Change the elevation
    (vla-put-ElevationModelSpace doc (+ currElevation 2))
    (alert (strcat "The new model space elevation is " (rtos (vla-get-ElevationModelSpace doc) 2)))
    ;; Reset the elevation to its original value
    (vla-put-ElevationModelSpace doc currElevation)
    (alert (strcat "The model space elevation is reset to " (rtos (vla-get-ElevationModelSpace doc) 2)))
GMT+8, 2026-10-28 13:18
