ActiveX 开发指南
相关分类
驱动程序路径属性 (ActiveX)
2023-1-3 17:52| 发布者: admin| 查看: 1553| 评论: 0|来自: AutoCAD
摘要: 指定 AutoCAD 在其中查找视频显示、定点设备、打印机和绘图仪的 ADI 设备驱动程序的目录。
支持的平台:仅窗口
工 务 局:
object.DriversPath
类型:首选项文件
此属性适用的对象。
只读:不
类型:字符串
设备驱动程序所在的目录。为每个路径指定驱动器号和路径。用分号 (;)分隔多个目录列表。
没有额外的评论。
工 务 局:
Sub Example_DriversPath()
    ' DriversPath. It then changes the value, and finally
    Dim currDriversPath As String
    Dim newDriversPath As String
    Set preferences = ThisDrawing.Application.Preferences
    ' Retrieve the current DriversPath value
    currDriversPath = preferences.Files.DriversPath
    MsgBox "The current value for DriversPath is " & currDriversPath, vbInformation, "DriversPath Example"
    ' Change the value for DriversPath
    newDriversPath = "TestDriversPath"
    preferences.Files.DriversPath = newDriversPath
    MsgBox "The new value for DriversPath is " & newDriversPath, vbInformation, "DriversPath Example"
    ' Reset DriversPath to its original value
    preferences.Files.DriversPath = currDriversPath
    MsgBox "The DriversPath value is reset to " & currDriversPath, vbInformation, "DriversPath Example"
Visual LISP:
(defun c:Example_DriversPath()
    ;; DriversPath. It then changes the value, and finally
    ;; Retrieve the current DriversPath value
    (setq currDriversPath (vla-get-DriversPath (vla-get-Files preferences)))
    (alert (strcat "The current value for DriversPath is " currDriversPath))
    ;; Change the value for DriversPath
    (setq newDriversPath "TestDriversPath")
    (vla-put-DriversPath (vla-get-Files preferences) newDriversPath)
    (alert (strcat "The new value for DriversPath is " newDriversPath))
    ;; Reset DriversPath to its original value
    (vla-put-DriversPath (vla-get-Files preferences) currDriversPath)
    (alert (strcat "The DriversPath value is reset to " currDriversPath))
GMT+8, 2026-10-27 04:29
