获取首选项绘图对象。 支持的平台:仅窗口 言论该对象包含存储在注册表中的“选项”对话框中“绘图”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesDraftingDatabasePreferences 例子工 务 局: Sub Example_Drafting()
' This example obtains a reference to the Drafting Preferences object
' from the Application Preferences object, and reads one of the Drafting
' preferences
Dim ACADPref As AcadPreferencesDrafting
' Obtain a reference to the Drafting Preferences object
Set ACADPref = ThisDrawing.Application.Preferences.Drafting
MsgBox "We now have access to the properties and methods of the Drafting Preferences object!"
MsgBox "The Drafting preference AutoSnapTooltip is set to: " & ACADPref.AutoSnapTooltip
Visual LISP: (vl-load-com)
(defun c:Example_Drafting()
;; This example obtains a reference to the Drafting Preferences object
;; from the Application Preferences object, and reads one of the Drafting
;; preferences
;; Obtain a reference to the Drafting Preferences object
(setq ACADPref (vla-get-Drafting preferences))
(alert "We now have access to the properties and methods of the Drafting Preferences object!")
(alert (strcat "The Drafting preference AutoSnapTooltip is set to: " (if (= (vla-get-AutoSnapTooltip ACADPref) :vlax-true) "True" "false")))
GMT+8, 2026-11-4 23:52
