ActiveX 开发指南
相关分类
文档属性 (ActiveX)
2023-1-3 18:03| 发布者: admin| 查看: 1792| 评论: 0|来自: AutoCAD
摘要: 获取文档集合。
获取文档集合。
支持的平台:仅窗口
工 务 局:
object.Documents
类型:应用
此属性适用的对象。
只读:是的
类型:文档
当前 AutoCAD 会话的集合。Documents
集合允许您访问当前 AutoCAD 会话中的所有文档或图形。Documents
工 务 局:
Sub Example_Documents()
    ' This example obtains a reference to the Documents collection
    ' and displays information about the loaded documents.
    Dim Document As AcadDocument
    Dim msg As String
    msg = vbCrLf
    ' Cycle through the Documents collection and retrieve the names
    ' of the loaded documents
    For Each Document In Documents
        msg = msg & Document.Name & vbCrLf
    Next
    ' Display loaded document information
    If Documents.Count > 0 Then
        MsgBox "The loaded documents are: " & msg
    Else
        MsgBox "There are no loaded documents!"
    End If
Visual LISP:
(defun c:Example_Documents()
    ;; This example obtains a reference to the Documents collection
    ;; and displays information about the loaded documents.
    ;; Cycle through the Documents collection and retrieve the names
    ;; of the loaded documents
    (setq msg "")
    (vlax-for Document (vla-get-Documents acadObj)
        (setq msg (strcat msg "\n" (vla-get-Name Document)))
    ;; Display loaded document information
    (if (> (vla-get-Count (vla-get-Documents acadObj)))
        (alert (strcat "The loaded documents are: " msg))
        (alert "There are no loaded documents!")
GMT+8, 2026-10-31 08:47
