确定将 OLE 对象插入图形时是否显示 OLE 缩放对话框。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。True 例子工 务 局: Sub Example_DisplayOLEScale()
' This example reads and modifies the preference value that controls
' whether the OLE scaling dialog is displayed when OLE objects are
' inserted into a drawing.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesSystem
' Get the system preferences object
Set ACADPref = ThisDrawing.Application.Preferences.System
originalValue = ACADPref.DisplayOLEScale
MsgBox "The DisplayOLEScale preference is set to: " & originalValue
' Modify the DisplayOLEScale preference by toggling the value
ACADPref.DisplayOLEScale = Not (ACADPref.DisplayOLEScale)
newValue = ACADPref.DisplayOLEScale
MsgBox "The DisplayOLEScale preference has been set to: " & newValue
' this preference in effect
ACADPref.DisplayOLEScale = originalValue
MsgBox "The DisplayOLEScale preference was reset back to: " & originalValue
Visual LISP: (vl-load-com)
(defun c:Example_DisplayOLEScale()
;; This example reads and modifies the preference value that controls
;; whether the OLE scaling dialog is displayed when OLE objects are
;; inserted into a drawing.
;; When finished, this example resets the preference value back to
;; its original value.
;; Get the system preferences object
(setq ACADPref (vla-get-System preferences))
(setq originalValue (vla-get-DisplayOLEScale ACADPref))
(alert (strcat "The DisplayOLEScale preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the DisplayOLEScale preference by toggling the value
(vla-put-DisplayOLEScale ACADPref (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-DisplayOLEScale ACADPref))
(alert (strcat "The DisplayOLEScale preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-DisplayOLEScale ACADPref originalValue)
(alert (strcat "The DisplayOLEScale preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-26 15:30
