指定光线、公差或通过矢量的xline的方向。 支持的平台:仅窗口 属性值只读:不 类型:变体(双精度的三元素数组) 光线、公差或构造线 (XLine) 的方向。 言论没有额外的评论。 例子工 务 局: Sub Example_DirectionVector()
' This example creates a ray and then changes the direction vector
' for the ray.
Dim rayObj As AcadRay
Dim basePoint(0 To 2) As Double
Dim SecondPoint(0 To 2) As Double
Dim newDirectionVec(0 To 2) As Double
basePoint(0) = 3#: basePoint(1) = 3#: basePoint(2) = 0#
SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0#
' Create a Ray object in model space
Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, SecondPoint)
ZoomAll
MsgBox "The ray has a direction vector of " & rayObj.DirectionVector(0) & ", " & rayObj.DirectionVector(1) & ", " & rayObj.DirectionVector(2), vbInformation, "DirectionVector Example"
' Change the direction vector
newDirectionVec(0) = 3#: newDirectionVec(1) = 1#: newDirectionVec(2) = 0#
rayObj.DirectionVector = newDirectionVec
' Query the new direction vector for the Ray
Dim retDir As Variant ' Note that return from DirectionVector property is Variant and not a SafeArray
retDir = rayObj.DirectionVector
ThisDrawing.Regen True
MsgBox "The direction vector of the ray has been changed to " & rayObj.DirectionVector(0) & ", " & rayObj.DirectionVector(1) & ", " & rayObj.DirectionVector(2), vbInformation, "DirectionVector Example"
Visual LISP: (vl-load-com)
(defun c:Example_DirectionVector()
;; This example creates a ray and then changes the direction vector
;; for the ray.
(setq basePoint (vlax-3d-point 3 3 0)
SecondPoint (vlax-3d-point 1 3 0))
;; Create a Ray object in model space
(setq rayObj (vla-AddRay modelSpace basePoint SecondPoint))
(vla-ZoomAll acadObj)
(setq vDirection (vlax-safearray->list (vlax-variant-value (vla-get-DirectionVector rayObj))))
(alert (strcat "The ray has a direction vector of "
"\n" (rtos (nth 0 vDirection) 2) "," (rtos (nth 1 vDirection) 2) "," (rtos (nth 2 vDirection) 2)))
;; Change the direction vector
(setq newDirectionVec (vlax-3d-point 3 1 0))
(vla-put-DirectionVector rayObj newDirectionVec)
;; Query the new direction vector for the Ray
(setq retDir (vlax-safearray->list (vlax-variant-value (vla-get-DirectionVector rayObj))))
(vla-Regen doc :vlax-true)
(alert (strcat "The direction vector of the ray has been changed to "
"\n" (rtos (nth 0 retDir) 2) "," (rtos (nth 1 retDir) 2) "," (rtos (nth 2 retDir) 2)))
GMT+8, 2026-11-25 17:12
