指定如果图形包含自定义对象,AutoCAD 是否要求加载第三方应用程序。 支持的平台:仅窗口 属性值只读:不 类型:枚举acARXDemandLoad
言论此属性的初始值为。acDemandLoadOnObjectDetect + acDemandLoadCmdInvoke 注意:此属性的值存储在 DEMANDLOAD 系统变量中。
例子工 务 局: Sub Example_DemandLoadARXApp()
' DemandLoadARXApp. It then changes the value, and finally
Dim currDemandLoadARXApp As Integer
Dim constant As String
Dim newConstant As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current DemandLoadARXApp value
currDemandLoadARXApp = preferences.OpenSave.DemandLoadARXApp
MsgBox "The current value for DemandLoadARXApp is " & currDemandLoadARXApp, vbInformation, "DemandLoadARXApp Example"
' Change the value for DemandLoadARXApp
newConstant = acDemandLoadCmdInvoke
preferences.OpenSave.DemandLoadARXApp = acDemandLoadCmdInvoke
MsgBox "The new value for DemandLoadARXApp is " & newConstant, vbInformation, "DemandLoadARXApp Example"
' Reset DemandLoadARXApp to its original value
preferences.OpenSave.DemandLoadARXApp = currDemandLoadARXApp
MsgBox "The DemandLoadARXApp value is reset to " & currDemandLoadARXApp, vbInformation, "DemandLoadARXApp Example"
Visual LISP: (vl-load-com)
(defun c:Example_DemandLoadARXApp()
;; DemandLoadARXApp. It then changes the value, and finally
;; Retrieve the current DemandLoadARXApp value
(setq currDemandLoadARXApp (vla-get-DemandLoadARXApp (vla-get-OpenSave preferences)))
(alert (strcat "The current value for DemandLoadARXApp is " (itoa currDemandLoadARXApp)))
;; Change the value for DemandLoadARXApp
(setq newConstant acDemandLoadCmdInvoke)
(vla-put-DemandLoadARXApp (vla-get-OpenSave preferences) newConstant)
(alert (strcat "The new value for DemandLoadARXApp is " (itoa newConstant)))
;; Reset DemandLoadARXApp to its original value
(vla-put-DemandLoadARXApp (vla-get-OpenSave preferences) currDemandLoadARXApp)
(alert (strcat "The DemandLoadARXApp value is reset to " (itoa currDemandLoadARXApp)))
GMT+8, 2026-11-30 09:03
